Bafang G06
redbike
9
42
I have been looking at building a fat ebike, I have been looking at the Bafang G06 motors but looking the specification apart the weight the 250/350/500/750 all look the same specification can someone help me with this?
Also the Rated Voltage is listed as (DCV) 36/43/48, why are there 3 voltages i am a little confused?
17,153
don't worry, Bafang make motors to suit customers, your choice is limited to what you can get.
What specifications are you after?
redbike
9
42
I have nothing planned yet, just wondering if there is any difference, i think i want to keep it road legal but is there is a big advantage or the 750w motor?
17,153
higher power models give more torque and more speed but all that depends on what the importer has ordered. You need to check the winding codes for what you want before ordering.
Code 16 is about the best compromise for 500W.
I only keep legal G06 models.
the code is the number in brackets - this is a code 10 motor, maximum no load speed is about 19 mph.
redbike
9
42
So there are different voltage G06 motors available 36v and 48v motor?
17,153
yes. You tell Bafang the voltage (usually 36V or 48V) and power rating (250W-750W) that you want, they'll wind the motor to suit your requirements.
Reactions: redbike
redbike
9
42
Thanks Woosh it makes much more sense now, do you sell a G06 250W motor on in own or in a full kit with battery?
17,153
Neohansen
May 14, 2020
[QUOTE = "Woosh, indlæg: 440299, medlem: 8175"]
modeller med højere effekt giver mere drejningsmoment og mere hastighed, men alt det afhænger af hvad importøren har bestilt. Du skal kontrollere viklingskoderne for, hvad du vil have, før du bestiller.
Kode 16 handler om det bedste kompromis til 500W.
Jeg holder kun lovlige G06-modeller.
koden er antallet i parentes - dette er en kode 10-motor, maksimal ingen belastningshastighed er ca. 19 km / h.
[/CITERE]
Hey do u know where i can buy part for that motor i need some nylon cranks
17,153
Sorry, I don't know.
I never had to send one back to Bafang for repair.
