Bafang For Boardman
17,291
if you go to specifications, it says FSA MegaExo. 73mm.
You can use the BBS01B - it will fit.
The kit comes with two M6 x 15 to fit 68mm bottom brackets.
As you have 73mm bottom bracket, you'll need to replace those two M6 x 15 with slightly longer M6 x 20mm.
Reactions: Koops
Koops
Apr 7, 2012
That’s great info, thanks. I’d like to fit the 1000W HD motor for off road use.
