Bafang CST gear stripped problem
patpatbut
860
79
Dear all,
After nearly 9000 miles, I managed to strip the blue gears. :(
I replaced the gears set from GBK 42T teeth (White gears ) but the motor is noiser than before.
Just wondering does the gears need to be "set" for several miles before getting quiet again?
p.s. I used carbon greases to them.
Pat
Was there an event that stripped the gears or did they just wear out?
I've got a feeling that the white gears won't be as good as the blue ones - probably not as strong.
patpatbut
860
79
Only part of the gear stripped. I believe it happened when I dropped from the pavement in high speed. I should have slow down but it is too late now
