201 rpm is a code 15 and it'll do 15mph, which I think you'll find a little slow. It'll actually do about 17mph with a fully charged battery if you're lucky. The code 11 or 12 are much better and will give a rel-world speed of about 20 mph. If you're planning to get from BMSBattery, they won't tell you which code number you'll get. You have to wait for the surprise when it arrives. It could be anything from code 17 (very slow) to code 11. Other suppliers should be able to give you the code number.
If you get a code 15 36v and run it at 48v, it behaves as a code 11, so you can order the motor and controller first (get a dual voltage controller) and if the Code number is high, get a 48v battery, if low, get a 36v one.
You need at least one good torque arm on the forks. Two is better, and they need to be properly installed. You can use the disk brake fixing on one side, but you need to be a bit more creative on the other.
Have a look at the forks to check that the drop-outs are nice and thick and have a bit of meat around them as well. I''ve seen some that I wouldn't want to put any hub-motor in. Rockshox and Fox are normally OK.
450w controller doesn't mean anything. What's important is the maximum amps it will give. Unless you like to pedal hard, 22 to 25 amps is about right for this motor in the front.
Hill-climbing is very good compared to a 250w hub-motor, but for serious hills, the 500w rear version is better. Why have you chosen front over rear? It's much easier to install in the rear. Although a bit more expensive, the 500W CST with cassette spline is the easiest of all. It just slots in with a single torque arm on the disc brake fixing, the battery and controller in a bag tucked in behind the seatpost, and away you go. Remember, if you have high power, you can always turn it down, but if you have low power, you can't turn it up. The 500w motors are the same size, weight and price as the 350w ones, so I don't see an advantage of the 350w ones unless you want lower power for a front motor. I wouldn't fit a 500w motor in the front.
I know I keep going on about it, but Saneagle's Kraken conversion is the best conversion I've seen. It's poweful, smooth, quiet, stealthy, and has long range. Here it is behind mine. We both have the same motor and battery:
