True, but they've got pretty good green credentials, will that do?but Green...
Sort of but kinda not. This is how they come from factory.As a relative ebike newbie I presume this thread is about engraving..am i on the right track?
If so ..nicely done!
Of course.Care to elaborate?..probably not!
Other threads on here explain so I won't go into it again, but this motor is completely EAPC compatible and UK road legal, runs at 15A with a continuous 250W of power and is rated as such.Oh ..ok thanks.for some reason i thought the bbs02 was not uk legal
Hehe. It's a thought.Sounds like exactly what i need.I wonder if a uk legal version of the HD model will ever become available. I presume that would be even more durable and take a huge amount of xxxt.
Hi Neal, hope you're well.Is this similar to the Em3 bbs01b, can it go to 25a ?
They are the same markings as all other BBSxx motors.Yes quite well thanks Darren,
Your pic didn't show but assume it is 15a lasered mark as per normal.
Absolutely!On Darren's website.
http://www.brightonebikes.co.uk/store/p69/Bafang[emoji768]_BBS02B_mid_drive_conversion_kit_36V_250W.html
Don't forget the commission Darren .
Just being cheeky .Absolutely!
I'll always do you a little tickle on another Lekkie Bling Ring or other bits.
Although that said, those rings last so long it could be a while before you might need another.
Cheers Neal Happy riding.
Sent from my E5823 using Tapatalk
I can set my BBSHD to UK legal spec using the Dillenger switcheroonie.Hehe. It's a thought.
I wonder whether the sheer weight of that hunk of HD motor might be somewhat counter productive to the power to weight ratio, and perhaps a slight overkill!
