I'm new here and new to the world of e-bikes. When researching there seemed to be some gaps in information regarding the fitting and use of these things.
My kit arrived yesterday and I fitted most of it yesterday as well (31/12/2020)
I intend to update and add to this thread as and when. As I've said above I got most of it fitted to make it useable but still need to do the brake and gear change sensors.
First of all, me and my background;
Early 50's bloke in the UK. I've always messed about with bikes ever since I got hold of some spanners as a child. I've also messed about with cars and have quite an extensive set of tools. I consider myself reasonably competent on bikes the only thing I draw the line on is wheel building!
The bike;
A 2019 Boardman MTX 8.8 aluminium framed hydrid. Front aero forks, shimano hydraulic discs and a 2x10 shimano drive train. I've also added a rear disc rack, full mud guards and even a Pletcher stand (anyone else remember those from the 70's / 80's? ... still as good as they ever were, well you can still buy them and they are brilliant!)
My concerns prior to buying the Bafang BBS01b;
Only one and that was if there was enough room between the motor body and the bottom bracket shell to allow cables and more importantly the hydraulic brake pipe. I couldn't find anything definitive online about this so it was very much a case of seeing how things would go. I'm happy to report that neither the brake pipe of rear gear cable caused an issue. The motor body could have swung a little further towards the downtube but if it had it would have crushed the brake pipe. Hopefully I've nipped up the motor lock rings enough, more on that later...
Tools needed;
General tools, 15mm spanner for the pedals, various sized allen (hex) keys, cable side cutters etc.
Special tools, chain breaker or quick plink pliers, crank arm puller, bottom bracket socket (mine was a standard square taper type in a 68mm bottom bracket shell). One thing also to consider with regard to removing the bottom bracket; they can be 'kin tight so a long breaker bar and large socket to fit the BB socket is a good idea.
A powerful soldering iron if you want to neatly install the power cables from the battery to the motor, on my kit they were very long and being quite fat difficult to hide. Also heatshrink tube and or insulating tape.
Rivnut tool and some M5 rivnuts, 7mm HSS drillbit and an electric drill. Note; I was lucky on my bike being an XL sized frame that I could get the drill inside the frame triangle. On smaller frames, this could be tricky and you'll probably need a right angled drill.
Oh, and cable ties, get some more, a bag of 100 should do it !
That is it for this post, next up preparing the bike... (and if anyone wants to chip-in with any better or alternative advice, please do so)
The bike;
Tools needed;
