I think it is override by display, cos the 1-5 PAS modes work increasingly. Yes I can enter the 2nd screen with 0512 password, but there is only speed limit (I change it from 25 to 40 and it works fine) and wheel D, thats all.The display overrides the computer settings if it is set to controlled by display
what display is fitted and can you access the 2nd screen with the password?
The thing is I got second bike with AEG system - its Prophete navigator sport with bit bigger AEG engine, and I can easily change any setting, the program works fine it's the controller causing the problem. I opened the AEG cover on Rivel and there are bafang numbers everywhere:The bike motor looks like a welded integrated model and not the BBS01 we think of as I kit form.
So settings look like they may be fixed and not able to be over ridden.
With BBS01,02, HD kits etc we never touch read or write flash on the bottom right of the screen in the 3 sub menu's on top of the page.
On the bottom left just press read to bring up current settings and then write to store any changes made in each sub menu.
I hope it is bbs01, software connects easily, I don't know if bafang built different engine types for AEG, what I know I got different AEG bike and programming is doable, so... My display looks like this:Not sure if the software is the same for that motor as bbs01 I remember reading on ES about problems and locked firmware does the display show more details about the battery range etc if that is the case I suspect it will not mod easily as the controller is not the same
Well I sent the no on controller (MM G310.250) to seller and he said it bbs01 old type controler should work for 99%, so I'm waiting for it and fingers crossedThat's not a bbs01 display I have ever seen looks like you have package made up by bafang to suit aeg requirements still
Do not think that's a bbs01 motor think that's a version of the max or ultra drive without all its plastic covers if so the software does not cover all the new motors
Hi, I know that the post is old now but can you tell if you succeeded in programming your bike? I am about to buy a bike that has a similar ComforDrive engine from AEG and I am interested in knowing whether or not I can reprogram it.Well I sent the no on controller (MM G310.250) to seller and he said it bbs01 old type controler should work for 99%, so I'm waiting for it and fingers crossed
