badass dongle?
Steven Dorrington
May 2, 2017
Southamptom
I picked up my Haibike for an absolute steal and he chucked in the badass dongle with it too. I managed to get it working after about an hour fiddling about with magnet position. However, the thing cuts in and out all the time or goes totally mental. the bike is not enjoyable to ride either with the badass on due to the unpredictability. I ride fairly hard over the mixed off-road terrain. has anyone actually managed to get a badass working smoothly or shall I just give up and get a Speedbox2? and yes it has a fresh battery in it!
6,478
all the dongle does is remove the speed limit so it should not be cutting in and out like that so id take the bike to a dealer to check the motor for a fault.
do you get any error msg on the display? as it should take seconds to put the dongle on and move the magnet to the right place.
it also could be a faulty sensor or loose connection in the motor so id also check that as well.
Steven Dorrington
May 2, 2017
Southamptom
yeah, i get what you are saying, however, i get no issues what so ever when I don't have the badass on. the bike rides like a dream but I just have that pesky annoying assistance limit. so i really dont think its a motor fault maybe its just an issue with the badass i have? sometimes i get a 503 error when the badass is installed and it reads no speed on the HUD. but remove the badass reboot the HUD and its all fine
6,478
well if it works fine with out it then the dongle must have a fault esp if it took you an hour to get the magnet in the right place as thats not right.
6,478
Izzyekerslike
455
415
Leeds, West Yorkshire
Please post a picture of the magnet position in relation to the Badass box. The Badass is sensative to position, but I know a guy that had the same problem and it was easily cured. However if you are using your bike mostly off road then a Dongle is really superfluous. Try riding without the dongle and see what you think.
Izzyekerslike
455
415
Badass boxes are pretty reliable..before you waste your hard earned money...post a photo
Steve A
704
414
Ashford, UK
Nothing wrong with the badass box. I would post pic so Soundwave can have a look. Speedbox 2 have their problems also.
Better option is the bikespeed rs
6,478
ill take a pic of mine but if he spent a hr messing with it then i guess he would have fond the right spot buy now lol.
the other down side of the bad ass dongle is water getting in it.
6,478
Steve A
704
414
Ashford, UK
Point is if there's problems fitting a badass, i think it may well be dangerous to fit an internal dongle that could blow the motor, lol.
My mate sealed the badass and no issues with water/moisture:)
6,478
i clean it and lube it near enough after every ride as it also lives in the hall way.
mud ;(
farmer
50
76
I rarely clean my cube, I fitted a dadass d. works incredibly well,but shall take it off ,as I'm not putting enough effort into cycling since,and let's face it, that's whats it's all about!
Reactions: LeighPing
IR772
931
1,044
Leominster
I can only see two cable ties is that safe.
Also does your free wheel make a loud ticking. Mine does.
sDuro wheels silent, Crank bros not.
6,478
yeah its the paw pins in the hub my m8s bike makes a right bloody row same sound just more high pitch.
