Assembling a folding e-bike
Keter Sharon
Oct 25, 2013
A, A
Hi,
I would like to build an e-bike from the TERN D8.
The problem is that the bike front fork axle width is 74mm.
All the kits i found require a minimum of 100mm width to assemble the motor and wheel.
I saw an electric TERN D8 bike once, so there must be a way to make it electric.
patpatbut
860
79
Hi,
Hi,
Not really. Three motors Q85, Tongxin and Keyde have 80mm width which make it easiler to spread the fork
You can find the information here
Pat
trex
7,703
2,671
or a crank drive?
The forks on my Dahon (same family as Tern) are also 75mm, and they're very stiff. Even a 5mm stretch could be a problem. I'd forget about a front motor. Fit a rear one so you can have any one you want. Just make sure that you get a high speed version (between 300 and 400 rpm).
Within about 2 weeks(hopefully), I'll be fitting a new rear motor to my Dahon, so I can give you a step-by step guide.
Keter Sharon
Oct 25, 2013
A, A
Isn't it more difficult to assemble a rear motor?
What is preferable a front or a rear motor?
What is the width of the rear axle on your Dahon?
What are the guidelines in selecting a rear motor? I believe is first must support the 8 gears the D8 has...
Tnx
MikeyBikey
237
23
Trouble is the OP wants to use a D8, which I think is the 8sp Hub Gear version? so rear version not possible. Could have crank drive or pick the derailleur version, P8? If not already bought, with rear hub & 8sp freewheel. Mikey :)
Keter Sharon
Oct 25, 2013
A, A
I didn't bought the bike yet, but I like the D8. Why I can't install a rear kit on them? Is it because of the number of gears?
This is the link to the bike:
Link D8 | Tern Folding Bike and Folding Bicycle Accessories | Worldwide
Is contains the specs.
MikeyBikey
237
23
Mmm, g series crystalyte looks big in 20in rim? Is it direct drive? 350euros + post & packing + import duty + controller + controls + wiring harness + battery + charger..
Have you looked at the Woosh Zephyr? Cheers, Mikey
It has derailleur gears, doesn't it?
I'll be fitting the Q100C to mine with 8 speed cassette. You can have 10 speed if you want with a cassette motor.
banbury frank
Banned
Jan 13, 2011
1,565
Hi The G motor is direct drive Built proof No import duty as euro country vat is included delivery is low about 28 euros and if you have a problem they are on the Phone
Frank
jerrysimon
3,292
112
Cambridge, UK
I am selling some 80mm wide motor kits HERE
PM me if you are interested.
Here is a conversion I have done a Dahon Uno
Close up of the motor
You have a choice of a low assist light (1.4kg) or medium assist (2.0kg) motor both 80mm wide.
Regards
Jerry
