Hi
I've got a relatively cheap Chinese Ebike and so far I've been very impressed with it.
Before my Ebike came into my life I was using a top spec road bike with decent frame and components and because it was expensive to me, it got lavished with attention to keeping it in perfect condition.
The Ebike was kindly gifted to me and it is a cheap Chinese one to be fair ,but I've always tried and treated everything I own with respect and I'm looking after this bike as I would compared to my other bikes.
You see and read of these so called cheap and inferior bikes literally falling to pieces after a few good miles but I think if looked after correctly they can be just as good as the more expensive offerings out there.
I think in some people's eyes a cheap Ebike is not worth spending any money on ,or not to bother servicing it or even bother cleaning it.Its something that's used and abused and run into the ground just because it was cheap.
And when it does eventually fail through neglect the bike often gets bad press and negative comments about it.
I've done 1500 miles on mine so far in the last month and a half and it's been absolutely perfect.Ive done a few simple maintenance things like keeping the brakes adjusted, nipping the head set up ect but apart from that there's been no unpleasant surprises.
I personally think if you treat even a cheap Ebike with mechanical sympathy it can last a very long time.
If you treat it like a cheap disposable item it will last no longer than an expensive bike if treated the same.
