I bought the bike deranged because it had been converted from the pedal magnet to one on the front whell, if you push the start button the bike will ride under the battery power but the motor does not cut out when the brakes are applied, when the front wheel is turned it also motors but again the brakes don't work , The Guy that did the conversion evidently tried to cure the problem by fitting a new brushless control box from Yongsan electric co which seems to be part of the problem.
I have traced the wiring on the bike and obtained a wiring diagram but nothing matches, I have many more wires than I need in the control box and none of the sockets and connectors match, none of the colours on the wiring from the the bike are the same as shown on the wiring diagram.
I tried to contact archo and longwise to buy a correct control unit but received no response, Please does any know where I can purchase the original correct control or give me any help to get the bikes brakes to operate correctly. WELL FED UP JOHN 0. bigjohn2710@yahoo.co.uk
