Anyone tried an MIB urban scrambler? (Super 73 style)
crunchie
24
43
UK
Are these style bikes any good on UK roads without front suspension?
Specs attached,
Motor:Bafang RM 060.250.DC 48v
overlander
532
42
With balloon tyres it will be ok, just need to watch that its not tiny if your tall.
Reactions: crunchie
Deleted member 33385
How is seat height adjusted on that bike? It'd drive me mad, not being able to change seat height.
6,486
crunchie
24
43
UK
after being let down on a super monkey and a rad I stumbled across these and bought one today . Being delivered tomorrow along with the rear basket can’t wait
If you’re wondering, out the box it reads 16mph top speed on flat but my gps says 19mph. It feels faster than my DIY ebike.
a lot of fun so far!
crunchie
24
43
UK
Seems pretty solid so far. I was a bit worried about no front suspension but I think I had tires inflated too high. Seems OK now.
Doesn’t appear to be a way to derestrict throttle
So it maxes out at walking speed.
Hi , they look great , interested in any updates.
Reactions: walking
devondunc
54
probably need a £20 throttle to replace it got mine yesterday with the optional basket very pleased quite a bit cheaper than similar bikes using much the same components .
only issue I have is the rear light doesn’t seem to work
and I thought it was dead before I found the on off switch. Under the battery :)
crunchie
24
43
UK
Yes I’ve not figured out the rear brake light.
theres 2 switches , one for battery and small one I presume for rear brake light.
Doesn’t seem to come on if headlight is on. Or if pulling brake lever.
overlander
532
42
What sort of size are they ? Would someone over 6ft fit on it.
3,993
It's limited by software in the control system, not by the throttle.
Reactions: devondunc
crunchie
24
43
UK
Any idea where this is from? Just packing?
I found if you wedge it above the battery, it stops it rattling! It was in the bottom Of the box but is cracked 41891
8,528
Also can help to stop the drop outs from being pushed in.
