Looking for first ebikes for my wife and me. I'm 6ft (183cm) 75kg, she's 5'6" (168cm) and around 80kg (bit of a guess but I'm not brave enough to ask ). Would like to try and keep cost of each to below £1500. Pref range in order of 40miles plus (no steep hills around here in our part of New Forest) with a mix of country roads and forest / gravel trails. Therefore I've been looking at the following:
Apache Matta E6 2020 from Rutland for the wife at £1299. Specs and styling look OK for the money - 36v / 468wh, hydraulic disc brakes, front suspension (admittedly Suntour NEX 63cm), 18" frame, not too heavy 21kg. (No bigger frame/crossbar version of the E6 available for me - Apache Matta E7 2021
has similar specs and 19" or 21" frame but no availability date yet)
Ampere Tourer / Tourer S for both of us. Either 10.4ah/375wh at £1249 (prob not big enough battery?) or 16ah/576wh at £1449. Very similar spec to Apache (hydraulic discs, Suntour NEX, 20kg. Might prefer the Ampere Explorer MTB for me...same pricing and spec but with Suntour XCT 100mm forks and slightly lighter at 19kg.
Anybody have any experience/knowledge of either of these brands and/or bikes?
Also on list are -
NCM Milano Plus good specs but price (£1599) and weight (28kg ) are concerns, along with after sales support.
Ezego Commute INT 2020. Cheaper at £1199 but only 400wh battery and no suspension. I like styling but wife not so keen on height of crossbar even the sloped one in the 15" frame.
Have looked at Woosh (Camino for me, Santana 3 for wife) but lead times are against. Santana CD for both of us is a possibility as in stock and very good value but not sure whether the crank drive would suit (and also they are pretty fugly).
Any views /input on these choices (or other suggestions in that budget range..Oxygen possibly?) gratefully received as starting to suffer from analysis paralysis....
Thanks in advice
Also on list are -
Thanks in advice
