March 2, 201214 yr Hi...I'm looking to buy a bike with the motor at the front and the battery at the back. ...this seems to me like an ideal arrangement....spreading the weight. .....any disadvantages with a front wheel hub ? .....thanks to everyone who's helping me get the right bike.....Mike
March 2, 201214 yr .....any disadvantages with a front wheel hub ? The obvious problem occurs on gravelly or slippery uphill slopes with injudicious use of power when front wheel slip can happen. It's not a major concern though or no-one would ride front wheel drive bikes. Indalo
March 2, 201214 yr Yes, grip may cause a bit of front wheel slip from time to time...also if fitting a powerful motor the front dropouts may not be strong enough so add a torque washer / kit... Frame mounted battery is ideal but I like rack mounted as I can sling some panniers over it hiding it away, I've not noticed any detriment to the handling... Edited March 2, 201214 yr by NRG
March 2, 201214 yr On steep hills I find I pull back on the handlebars quite forcibly so as to get more pressure on the pedals, thereby reducing the weight on the front wheel, not an ideal situation if you have front wheel drive! However I am talking about steep hills, so I suppose it depends on the sort of terrain you will be cycling in and I do like the idea of the weight being spread more evenly with a front hub motor.
March 2, 201214 yr Mike Bike frames are designed to be pushed from the rear, not pulled from the front, and front wheel drives put unnecessary strains on key points, especially the forks and headset. They do allow for extra gears, but that seems overkill when using a motor. Some argue a front wheel drive allows for hub gears at the rear, but personally I prefer to be able to maintain gears easily, rather than replace a whole hub. Front wheel motors do affect steering and control, especially in the wet and on gravel.
March 2, 201214 yr My personal preference for hub motors is a front wheel setup for normal road use. It is only when riding off road on very muddy or slippery surfaces that a rear motor has the advantage of better traction. This is not a biased opinion because we sell both front and rear wheel conversion kits.
March 2, 201214 yr or better still battery in triangle........ yes down at the bottom, ideal position
March 2, 201214 yr With hub motors I have a personal preference for rear hub which in my view gives a better handling feel, and in my case it's also better for pulling heavy trailer loads. The differences with compact front hub motors aren't great though, and with a front hub there is the benefit of two wheel traction when pedalling, cycling's equivalent to 4 x 4s when off road on the rough stuff.
March 2, 201214 yr Yes, I almost forgot about the 2 wheel drive advantage of front hub motors. Then there was the man who went to considerable lengths to convert a Torq from front to rear motor resulting in the legendary TR1, I guess that proves where his preference lies.
March 2, 201214 yr Front hub and battery on the seat tube gives a nice balance for carrying up steps and surely less wear on rear tyre . More even weight distribution when parked on a propstand too .
March 2, 201214 yr Front Hub + Rear Battery Rack PROS 2 Wheel Drive Even weight distribution for carrying better all round tire wear Easy Install / Wheel swap Good Handling Stealthy If fitted in Panniers CONS More wear on head sets and suspension forks Weaker dropouts on the front Traction on uphills Not as stealthy Edited March 2, 201214 yr by Scottyf
March 2, 201214 yr I have one of each (two different bikes!) and generally prefer the feel and handling of a rear hub. Also you do have to be careful about wheel spin with a front hub, as has been pointed out; we have a gravel drive, so I have to watch what I am doing as I set off from standstill. However, I do also like hub gears, and the advantages that I see in having those far outweigh the slight drawbacks of a front hub motor.
March 4, 201214 yr My experience is that the consequences of a slip in the front wheel is a lot worse than slip in the back. I can recover from a back wheel slip, not front. I slammed on the front brakes once in snow and the bike goes down. Slamming of the back, you get fish tail but can recover.
March 4, 201214 yr Totally agree with ed_wanna_ebike. Bicycles were always meant to be rear wheel drive and this is very much my preference. Also a motor on the rear and hidden battery and controller in a pannier bag on a rear carrier is very stealthy. I does put most of the weight on the back axle but is not that noticeable. I would hate to lose grip on the front wheel. That is a definite off!
March 5, 201214 yr I have two bikes one fwd one rwd I prefer rwd but I would love to have the batteries at the bottom of the triangle.
March 5, 201214 yr Hi...I'm looking to buy a bike with the motor at the front and the battery at the back. ...this seems to me like an ideal arrangement....spreading the weight. .....any disadvantages with a front wheel hub ? .....thanks to everyone who's helping me get the right bike.....Mike I don't know if anyone has mentioned the obvious one already, but the main disadvantage is that your bike obviously stands out as being electric...a rear motor looks more discrete but if your battery is on show anyway then it's not likely to matter much is it really. I've been riding with a front wheel hub motor for a year now and that's the only thing I dislike about it really, but apart from that, I've had no problems with handling. I've never ridden a rear hub so I can't compare.
March 5, 201214 yr I think my front drive Alien and Peugeot have only been identified as electric once or twice but the PCS gets spotted all the time...must be the battery and behind-the-seatpost configuration...
March 5, 201214 yr must be the battery and behind-the-seatpost configuration... Yes, I think that's a real giveaway as it's common to so many ebikes. Cytronex are still probably the stealthiest but they're not everybody's cup of tea. Rear hub-driven bikes can appear perfectly "normal" if the battery is rack-mounted and covered by large pannier bags. I rather enjoy being asked if my bike is "one of those electric thingies" and don't mind at all having the opportunity to describe how it works. In my experience, most people who ask seem to imagine that the bike can be ridden without pedalling as, of course, many can. Unfortunately, if I attempt to explain the difference between my pedelec and those electric mopeds, I can see their eyes begin to glaze over. I know that's the time to wish them a good day and be on my way! Indalo
March 9, 201214 yr Author There seems to be a deal of mixed opinion on the subject of front wheel drive but after my latest bad accident I daren't risk another, so much as I liked the look of the Kudos Eco it appears that I must have a rethink. I have fallen off no end of times with varying ammounts of damage to my body and my ego but this last episode really made me consider all options and I doubt that I can risk another front wheel drive. I'm riding again now but with a great deal of trepidation, every time I see a bump or an imperfection in the road my heart skips a beat Is my bike too big for me ? ....I've struggled to reach the ground on any number of occasions....there must be some kind of formula...the crossbar on my bike is 30" from the ground and my inside leg measurement is 28.5" I understand this bike to be a 19" frame and measured from the seat post to the crank, that's what it is. ...what's an ideal size for me ? ...what's the rule ? ...any advice...other than don't bother ...appreciated...Mike
March 9, 201214 yr With that inside leg measurement you'd be a lot happier with a 17" frame and 26" wheels Mike.
March 9, 201214 yr the crossbar on my bike is is 30" from the ground and my inside leg measurement is 28.5" Yikes When you stand over the crossbar there should be about an inch maybe a little more gap between the bar and your n..s When sat on the saddle, with the pedal at the lowest point, your leg should be almost but not quite straight (easily adjusted by saddle height). I find saddle height critical for comfort. Regards Jerry Edited March 9, 201214 yr by jerrysimon
March 9, 201214 yr Hi Mike, Firstly, I am not going to tell you what bike or frame size to get. I will only tell you about a friend of mine who seems to make a habit of falling off his crank motored bike. So far this has only happened at low speed and he has not suffered any serious injury to date other damaged pride. In my opinion, he is riding a bike that is too big for him and he is not able to control it if met with an obstacle that needs to be steered around or has to stop suddenly. Please don't be offended Mike, but is your balance what it used to be? Maybe you try a bike with a smaller frame, powered or not and see how you get on with that.
March 9, 201214 yr When sat on my bike i can't touch the floor. I can if i place my feet on a curb. Just if sat on the seat I cannot. Mines a 19inch frame and 700c wheels and i'm 5'10 I think its right. Might be slightly to big but as its straight line road riding I dont have to turn so sharply. It does make it more difficult to jump though as the wheel base is longer. Smaller bikes are much easier to chuck about. Edited March 9, 201214 yr by Scottyf
March 9, 201214 yr I'm around 5' 11" and ride a 54cm 700c wheeled road bike, but for fast 'chuckability' around our narrow streets with no pavements and a mixture of cars and pedestrians, I much prefer a smaller framed bike. I use a 16" frame Inbred and a BMX as e-bikes, both with front motors. We tried 2 tandems of different size with front and rear motors, the front wheel driven smaller frame won by a considerable margin. Alan
