Here's a rabbit hole. I jinxed the 10000 mile YOSE motor.
The controller[36/48v KT sine 14a] has done about 5000+ miles in 48v mode
Motor 250w 36v as mentioned 10000+
PAS & 1 to 4 cable changed for new once a year[ish]
KT LCD3 over 10000
Throttle half twist a year old
So I got caught in a mini blizzard lasting about 15 mins, so I am assuming some sort of water ingress.
I went about 4 miles yesterday all was in sound working order, however the journey back was fraught with a few minor motor sputters and judders, then a quick error 1, switching on and off, error 1 then error 3, on and off again then PAS and throttle would not engage. After a brief pedal I restarted the kit to find, a brief motor engage, followed by a grinding noise, quickly dying to no power, but 1000w on the LCD [never goes about 652 @ PAS5] and either high speed readings or 00mph.
A tad more no power pedalling then I unplugged the throttle, switched her back on and power and PAS was restored enough to make it home although it did feel a bit sketchy limited battery info, speed reporting and wattage info was out on the LCD.
I took the motor wheel off and removed the inners[needed doing TBF] to inspect the internals a part from the lack of grease{it has turned to powder however the factory black grease around the nylon gears was a little thinner than I remember but still there] All looked ok there was some minor pitting, the outer bearings worked and no water ingress as far as I could see. I re-greased it.
This leads me to my odd question. My intention was to inspect for water ingress on the halls, now I swear I have had the side plate off this motor before, however I could not get it removed... Do all side plates, the main cover that shields the HALLS come off? I didn't want to brute force it until I have check all other avenues.
I do have...
A different battery
A new 1 to 4 cable
A new PAS
A new 17a sine
and A new throttle
Just not a motor!
I put the whole thing back together and it ran fine today for 1 mile, then it started acting up again however it did restore its self and make it to the destination. On the journey back the PAS was causing the issues however when I removed the magnets from the PAS and just used the throttle there was no issues all the way home about 3 mile.
First thoughts that come to mind folks, no major biggy I just thought it may be interesting to gauge opinions.
My Plan
Check cables
replace controller & PAS
KT LCD3 over 10000
I do have...
A different battery
A new 1 to 4 cable
A new PAS
A new 17a sine
and A new throttle
Just not a motor!
My Plan
Check cables
