Am i doing something wrong?
Clare the Rear
47
24
Ipswich
I've been given the 'secret code' But my Oxygen S-Cross MTB motor still cuts out at 20mph! I've tried running with the wheel size turned down aswell but it makes no difference. Is there something else i need to input as i've read this model will do about 25mph+ Clare :confused:
If you turned the wheel size down, the speedometer will give you the wrong result. It'll show slower than you're actually going. Make sure it's set to 700c or 28"
Clare the Rear
47
24
Ipswich
Thanks, i've tried a few different wheel sizes just to see if it would go faster before the motor cuts out. Plus i've got another speedo fitted to give me a true reading along side the original.
Did you put in the secret code to adjust the speed limit?
