Jobsworth Planet X Bike Stand - £14.99 + £6.99 Delivery @ Planet X
JOBSWORTH BICYCLE REPAIR WORKSTAND. Super stable, height adjustable and featuring a built-in tool tray. Durable steel construction Folds easily for storage Includes adjustable tool tray. Durablable steel construction Folds easily for storage Includes adjustable tool tray Rubberised rotating...
www.planetx.co.uk
From the website
Featuring a bike friendly rubberised jaw, to protect paintwork and finishes the clamp can be rotated by 360 degrees for full access to hard to reach areas.
The additional stem clamp provides added security so you can keep your bike where you need it when working on more delicate tasks.
The Jobsworth Bicycle Repair Workstand has an adjustable height of 107cm to 188cm and is strong enough to hold bikes weighing up to 25KG (55lbs).
With a super stable four leg, you can work on your entire bike easily and make cleaning difficult areas such as your drivetrain a simple task.
The Jobsworth Bicycle Repair Workstands tough steel construction ensures long lasting durability and the entire stand folds away for convenient storage when not in use.
Including an adjustable tool tray the Jobsworth Bicycle Repair Workstand has everything you need to take the strain out of bike cleaning and maintenance at home.
Jaws suitable for all frame and seatpost 25-40mm diameter
Max load : 25KG (55lbs)
