AKM Hub motor
gspeed
17
Has anyone tried AKM hub motors ?
I was considering this one
because it's particulary light
Stephen
2,858
Woosh sells the 85SX, which I'm sure he wouldn't if he hadn't tested it out well.
85SX 2.0kgs 100mm cassette 40NM AIKEMA lightweight rear motor wheels, available in 26" and 700C(28") rims
Reactions: Jonah
Jonah
882
246
EX38
I have this motor and am very pleased with it. Up to 500 miles use over the last 2 months.
8,843
Stephen
You can buy it at the site in the link.
3,994
AKM motors are really good. They're very reliable, smooth and quiet with the right controller, and they pack a fair punch for their size. They're my favourite motor after trying just about every other brand over the last 10 years.
ALW
7
I have the 85SX from Woosh and it's great. Very quiet and smooth.
8,843
The AKM 128c is quiet as well, my preferred hub motor and is fitted to my 700c touring bike. It can take 25a @36 or 48v for hill climbing.
Carl18650
Have somebody tested the akm 75sx? Is as good as the others? Haven't found a single review
harrys
417
113
Chicago, USA
I have installed several AKM100H's on 20" hubs with 20x2" tires. One bike has 8000 miles. I don't think I would go any smaller than than 100H for a 26" wheel, and would prefer the larger AKM128,
4,226
I tested one. It was sensorless, so had to be careful with choice of controller. I used a sensorless controller, but it still lost sync with it whenever I opened the the throttle to full. I solved that by experimenting with the settings. I think theyre mainly sensored now, so you shouldn't get that problem. I had it on a road bike and the power was OK, but wouldn't be my choice for a 95kg+ rider with hills.
Make sure you get the right RPM for what you need. 201 rpm is OK up to 15 mph in 26" or 700c wheel. 328rpm is too fast for big wheels, but a good choice for 16" or 20".
Carl18650
Thanks for the info, I have one with a speed sensor included and I went with the 201 and plan to install it on 700c so its nice to know that is ok, My main concern isn't the motor's performance when it's on, but rather the amount of resistance or drag it creates when it's off and I'm pedaling on my own. Could you share your experiences regarding how this compares to riding a traditional, non-electric road bike? I plan to use the motor only occasionally and will mostly ride with it turned off. Thank you.
8,843
Internal motor reduction is high so riding unpowered will be fine.
4,226
All the AKM motors have relatively low resistance. All motors can take a few miles before they free-up completely.
Reactions: Carl18650
