AKM-100CST Cassette 36V250W
QuestionsQuestions
13
I am told that most geared hub motors have clutches so the hub will turn freely when not powered. Does anyone know whether the AKM-100CST Cassette 36V250W from topbikekit.com has a clutch? I have tried asking Topbikekit but I am not convinced they have understood me.
8,533
Yes it has, as all geared hubs do.
The AKM hubs have a higher gear ratio then a lot of major producers like Bafang. Mxus or kit suppliers like Yose (Bafang hubs) etc,etc. In my view the AKM hub I have is much better to ride unassisted then the above hubs I have.
QuestionsQuestions
13
Hello,
The AKM-100CST motor, recommended controller and throttle arrived. I've got it on a trueing stand but the most I can get out of the motor 250rpm with a 36v battery. I should get 328rpm.
Don't have display.
Any suggestions?
AKM-100CST Cassette 36V250W EBike Rear Driving Hub Motor 20/28/32/36 holes (AKM100CST EBike 36V250W motor)
• Holes 32, RPM 328
T-06S 24V/36V250W Torque Simulation Sine Wave Brushless Controller for Ebike (T-06S controller)
• Display No display
•Throttle Wuxing 21x thumb throttle
8,533
How do you know it's is 250rpm ?
QuestionsQuestions
13
I've put a magnetic on the hub and I have a counting meter. After 60 seconds 250 is displayed on the meter. I also noticed that the motor gets to maximum speed on about half throttle.
QuestionsQuestions
13
There isn't a speed limit wire on the controller, I checked.
Is it likely the controller has a default 250rpm limit? I've read I might need a display to change the default setting.
8,533
BMS have been known to get their labelling wrong.
I and a few others bought the Q128C/AKM 128c with a 201rpm winding which should be about 15 /16mph but in use it was capable of 19/20 so in fact was a 250/260 rpm winding.
8,533
The controller doesn't affect RPM of the hub, only the watts output depending on the amperage. Voltage does, If you run it at 48v you will see a 33% speed increase over 36v.
