Hi,
I have some drivechain noise from my Agattu (just over 500 miles usage). I am trying to find out what the cause is - I have adjusted my hub gears which were slightly out and cleaned the chain and sprockets. I noticed that the chain tensioner (I think that's what it is) is spring loaded and was sticking slightly - so I cleaned everything and slackened the bolt a fraction. The question is should this bolt be slack or tight? Advice gratefully accepted. BTW the gear change is fine.
