Thanks Flecc. If the 8 speed chain does fit it would give the greatest flexibility of options.
I re-found that link to the Todd Fahrrer Giant Xtracycle and he was indeed adapting for a 9 speed DualDrive. An interesting conversion but increasing the range of assistance to such greater speeds must cost in terms of range. I reckon assistance up to 15mph and especially the help up hills when loaded will be just right for an Xtracycle.
100 kilo weight limit on roller brake would give 10 kilos for bike and load
. I was more thinking V or disc. Apparantly it's easy to lock up the rear on an unloaded Xtracycle as the weight is more evenly distributed front and rear than on a standard bike.
I think what I'd most likely do is try it with a 26" wheel singlespeed to check the feel of the X / Agattu combination and then if it feels 'right' choose from available hub and gearing options.
I'm making a bit of an assumption as well that the Agattu is a bit heavier built than the forthcoming pro-connect and will therefore retain a bit more rigidity with the Xtracycle. Of course the bulk of the weight difference might just be down to rigid forks and lighter tyres and the frames be very similar.
It will be nice when the cross bar version arrives of Agattu arrives to see if there is any difference in the rigidity department. Actually it'll be nice for the folk with them on order to get riding them
