Advice on Carrera Subway E
DB-001
Jun 17, 2020
Hi All,
Just took the plunge last week and purchased a carrera subway e from Halfords alongwith the rear pannier with single screw hole.
Having significant difficulty locating a suitable kickstand due to fixing type (clamp type seems like it would interfere with cabling). Halfords couldn’t recommend one - Can anyone recommend a good kickstand suitable for this bike that won’t cause issues? I’ve noticed there seems to be 2 holes on the fixing to the outside of the rear disc brake. Wondering if this is for a certain kickstand fixing?
Also, for the rear pannier, it has a single centralised hole on the back. Do I need a special bracket to fit rear light as I can’t find any rear light which seems to work with this?
Advice would be appreciated.
thanks
Yvonne
Jul 2, 2020
Clydebank
Hi All,
thanks
Hi i have the same problem purchasing kickstand, any recommendations where to get one for carrera subway e bike ladies?
DB-001
Jun 17, 2020
So I actually made some headway on this. Turns out the bike had an integrated 40mm direct mount on the frame. One I figured this out, problem solved. For someone not used to more expensive bikes, took a while to figure out that’s what the holes were for!
Yvonne
Jul 2, 2020
Clydebank
You guys need to help us to help you. Show us what you have and what the problem is.
can you attach a pic of the area the kickstand goes and secondly did you manage to get kickstand to fit ?
