Advice on buying an E-Bike
El Fusilado
7
So, thanks to everyone that replied to my earlier post. I dithered somewhat and then went on holiday so missed out on the Argos bargains. I'm not sure they were entirely right for what I wanted but they were certainly cheap. Can I have your views on the following four options. It will be for riding around Wimbledon Common and on the road around Wimbledon. For leisure rather than commute. I'm 5 foot 7 and 96kg, and a fairly mobile 60 year old. I have a non Ebike Hybrid currently that struggles on the Common a bit. Some of the cycle tracks are a bit gravelly! I am also very non handy when it comes to the mechanics - so I want something easy and cheap to maintain. I'm also leaning towards a step through, anticipating declining mobility over the years to come! So favouring the Sanatna 3 and Ridgeback but slightly worried that the tyres might not be up to the Common. Any other suggestions gratefully received
ELEGLIDE M2 Electric Mountain Bike 27.5"/29"
649​
https://www.electricscooterslondon.com/collections/electric-bikes/products/eleglide-m2-electric-mountain-bike?variant=44804086038752
I would add mudguards and panniers
Santana3 with 17AH battery
1049​
https://wooshbikes.co.uk/cart/#/category/uid-1
Metroneer EG 1.0 Comp Gravel E-Bike
699​
https://www.merlincycles.com/metroneer-eg-10-comp-gravel-e-bike-282643.html
I would add mudguards and panniers53 cm
Ridgeback Electron Front Hub Drive
849​
https://www.freewheel.co.uk/ridgeback-electron-front-hub-drive-varrb21990
thelarkbox
1,500
469
oxon
Basic pas control is simply speed limited so you get full power until the speed cap for each pas level is reached..
It can be counter intuitive to start with - messed me up a bit at least.. but it only takes a few outings to get used to it and a simple crack of either brake lever is just enough to invoke the brake cut off of the motor should you need to temper the power to navigate situations.
Reactions: El Fusilado
Peter.Bridge
1,583
727
The only way you can fix that is to change the controller to a KT one, which costs about £80. Your bike has the controller integrated into the battery case, so you'd have to mount the KT controller in its own case or in a bag.
I notice tbk has KT controllers for Hailong battery mounts - would that be a possibility ?
El Fusilado
7
Thanks for the heads up Peter. Following thelarkbox comment, I think I will give it a few more trials to see if I get used to the quick release of power. It is noticeably more potent than other e-bikes that I've tried! What is tbk?
Peter.Bridge
1,583
727
3,746
It depends which mount. There are three different ones. Also the OEM integrated controllers are potted. The TBK one would be vulnerable if not potted. I think a separate aluminium box type is always a better solution. It gives you a lot more options for size and power.
