Advice needed.
slow worm
Nov 21, 2024
Hello, I bought a converted carrera with a 350 watt yose rear hub motor recently, it's got the C500 display and a yuishi 18 amp max controller, I've found the advanced settings and turned the max amps up to 18 amps, it does a little over 20 mph on the flat but because I work out in the sticks I decided to add a 250 watt yose front hub motor I have two throttles and use the front hub only for steep hills, it works surprisingly well but me being me wanted a little extra oomph, I've bought a luishi 18 amp max controller but the display julet plug is slightly different, one end has an extra pin, any ideas? I was thinking of upping the max amps to 16 or 17 amps for short bursts, batteries aren't a problem because I'm running 3 with a combined total of 46 ah's.
thelarkbox
1,209
369
oxon
Yikes thats an unusual config. what hills terrain do you cover that needs the 2nd motor??
you can run some controllers headless (without a display) by throttle only by shorting the pins #1 (red wire battery voltage), and #2 (blue wire, 'start') to turn it on. if julet(waterproof) plugs/sockets, the keyword 'pinout' in a search should get you where pin-count starts from..
So you could install a switch to make the above connection on demand and wire up the one throttle to both controllers. Throw the switch to engage/disengage the front motor when you come to the big hill or spot a plod and need to exit stage left pdq.
Personally id pull the 350w motor and run within the regs the 18a controller with a 250w motor only but im boring and like having insurance etc..
edit imho 18a max current setting will have little effect on a 250w motor running on the flat, but if labouring at a slow speed up a long hill over a mile or more could suffer from overheating .
