A2B Metro 2 1/2 Years Old
NickTurner
Jan 22, 2013
This bike is about 2 1/2 years old excellent bike minor chips to frame from bike lock but other than that runs perfectly. Had a new engine/hub fitted 6 months ago but only been ridden 10 x since. The battery has had about 150 charge cycles so is in good order. Moved from london to suburbs so bought a car.
Please call for further info
Colour Blue
Maximum road speed under power - 15.5 mph
Maximum off-road speed under power - 20mph (activated by off-road switch)
Up to 20 miles* unassisted range (extendable to 40 miles**)
Battery chemistry: lithium ion
Nominal voltage: 36 volts
Continuous power output: 250W
Real-time state-of-charge indicator
Frame: TIG welded 6061 aluminum
Suspension (front): Ultra Motor shock-absorbing front fork (80mm travel)
Suspension (rear): Ultra Motor shock-absorbing swing arm (60mm travel)
Tires: 20 x 3.0 Kenda Kraze
Gears: Alivio derailleur with 7-speed twist shift
Brakes (front and rear): Avid BB5 disc brakes
Saddle: oversized Ultra Motor comfort saddle
Weight of A2B Metro: 31.1kg
Weight of portable battery: 5.9kg
Weight of A2B Metro with battery: 37kg
£1000 Cash on Collection Esher Surrey
07505 370142
