A Solution to Punctures for Fellow Bike Enthusiasts....
Heinzja
41
15
**Subject:** A Solution to Punctures for Fellow Bike Enthusiasts
Dear Bike Lovers,
As fellow enthusiasts in this community built on teamwork and knowledge exchange, I would like to share my experience as a newcomer (despite being in my 70s and having cycled all my life) regarding a common challenge we all face: punctures. I believe I have found the perfect solution for myself!
**No More Punctures!**
Many of us have encountered punctures and have sought various solutions, from purchasing “Slime” bottles and “Slime” inner tubes to investing in Schwalbe “puncture-proof” tires at £35 each. Ultimately, I discovered solid tires from Green Tyres (link), which have provided some success, albeit with limitations. While Slime is effective for tiny, slow punctures, using glue patches for repairs can be tricky. Green Tyres, priced at only £35 each (cheaper than Schwalbe since they do not require an inner tube costing £5-£10), do wear down like regular tires. When they become bald, they must be replaced—especially in winter. Additionally, replacing a spoke or nipple can be frustrating due to their tight fit on the rim.
After much experimentation, I found the best alternative that has kept me puncture-free for over ten years. I use a Schwalbe tire (e.g., 26x200) and insert an old, worn-down Schwalbe tire of a smaller width (e.g., 26x175) inside it, having cut off the metal beads cleanly. This “inner tire” not only protects the sides of the outer tire but also prevents damage from side impacts, such as those caused by brakes or debris.
When the outer tire wears out, I simply replace it and can use the “inner tire” for another bike or wheel if needed (provided I start with an appropriate size, such as 26x175 inside 150 or 26x195 inside 175, and so on).
The additional weight of a few hundred grams or the slight increase in rolling resistance is negligible, especially since we are all riding electric bikes, which typically weigh around 10 kg more than standard bicycles.
I encourage you to consider this solution. As I mentioned earlier, it has kept me puncture-free for over a decade, even as I cycle daily in winter and adverse weather conditions, navigating bike lanes littered with glass and plastic debris from accidents and discarded bottles.
Thank you for allowing me to share my experience, and I hope it proves helpful to you! Or what do you think about my “free” solution...?
Raboa
897
318
53
I have done myself, I use a cheap road thread tyre inside a road / trail tyre thread tyre and sand the cut edges a bit. The advancement in tyre technology has made this method obsolete to a degree, it still works though.
Az.
2,170
983
Plymouth
Nah... I think I will keep ignoring this problem :)
Thank you for positive contribution to our community. Unfortunately most newcomers want quick advice how to break the law and get away with it. We need more positive people like you.
3,953
Here's my experience: I bought a second hand Claude Buttler MTB and went out for a ride with a close friend. it didn't take long before I noticed that I was pedalling with some effort, while he was freewheeling down a gentle incline. I assumed that something was wrong with either the wheel bearings or the brakes, so I stripped them down, cleaned and lubricated them, and adjusted them.
Unfortunately, it made no difference, so I carried on for a few weeks. I then had a brainwave to try more slick tyres, and, of course, when I tried to take the old tyres off with great difficulty, I found that there were two tyres on each wheel. With the new tyres, it was perfect. Some difference probably came from the slicker tread, though I should add that the old outer ones were pretty worn. I'm putting the majority of the resistance down to the double tyres.
I probably wouldn't have noticed the problem if it wasn't for riding along with my friend on a similar bike.
Raboa
897
318
53
The one thing that will never go away is punctures.
I have had punctures in marathon plus tyres, both in the thread and the sidewalls.
You can now get tyre liners, slime inner tubes and tape, anti puncture liner tape.
Anti puncture tape seems to be 1mm (usually) thick pu tape. Buy some 3m pu tape and save yourself some money.
Heinzja
41
15
Certainly, it’s important what kind of tires (and the air pressure) are used. You wouldn’t go jogging in wellies! The resistance is a bit higher, but with an electric bike and the “funny frames” (a bit longer and wider, with the fork set away from the down tube), these bikes/frames are not really built by classic racing bike frame builders.
When you see where all the frames are made—Turkey, Korea, China, Czech Republic—these countries don’t have the same long-standing tradition as Gazelle in the Netherlands or even (old) Raleigh, or Italian companies like Colnago, Pogliaghi, Masi, and others. Electric bike frames are not exactly the epitome of beauty (just look at Freego without a battery); they ride like a tandem without the second person behind! Many come with a very heavy steel suspension fork that weighs as much as a racing bike on its own. They may look fast and nice, but they hinder performance more than they help.
A good bike frame is like a pair of favorite shoes: they fit well, and you can feel the difference—you feel at home! The price is secondary because the feeling is what matters. Every human body is different, and every bike frame is different. Finding the right frame or bike is a matter of luck and a long search, and it never works out with mail order, eBay, Gumtree, “from a picture” or without a test ride for longer distances. (You wouldn’t buy shoes out of a catalogue... or?)
On most electric bikes, you can’t even ride “hands-free” for 100 meters without wishing you had some diapers on hand! When you can take both hands off the handlebars after a few meters of test riding, then you’ve found a nice bike that you can ride with pleasure, feeling safe and secure and then you don’t need to “hands-free” anymore for your own and others safety ....
3,953
I had a three inch nail buried two inches into the tyre, and it still didn't go down when I pulled the nail out.
(35) Do puncture resistant tires work? | Pedelecs - Electric Bike Community
georgehenry
1,454
1,272
Surrey
You do not need to spend £35 for a Schwalbe “puncture-proof” tire . When I bought a new one recently {04 10 2024} it cost me £13 plus delivery postage for a Land Cruiser Plus. Just shop around.
3,953
Sorry, I should have said, Spa is where I got it, and have bought quite a few things from them.
Thanks to you too. If you hadn't made that comment, I wouldn't have got my 4 tyres for £52 Inc shipping. I quite like Land Cruiser tyres. They're not as puncture resistant as Marathon Plus, but grip much better on leaves, snow and muddy surfaces.
Cyclist
My solution to punctures(hybrid bike) is a decent tyre, fattest possible with mudguards: Schwalbe Marathon non plus at back(28x1.75"), Marathon Supreme @front(28x2"). And do not overinflate, say 35psi max.. Just swapped last pair and they lasted 10 years, cca 20k km, and no punctures at all..
