Introducing the new 85TS kit:
Only 3 components to install: the motorwheel, the battery and the LCD.
The motorwheel in this kit is state of the art as far as conversion kits go.
Inside the cassette freehub body, the maker has integrated a torque sensor, a pedal assist sensor and a speedometer.
This high degree of integration is the key to deploy this kit on high end bikes, even those with carbon frames and pressfit bottom brackets.
The battery uses also the latest 21700 cylindrical cells from Samsung, 36V 20AH or 720Watt Hours, enough for a whole day of cycling even by the most enthusiastic cyclists.
The colour LCD is clear and gives excellent result even in bright light.
Give your next bike this best kit at the moment.
It's so simple!
Integrated motorwheel with Aikema 85SX motor core (maximum 40NM):
36V 20AH 720WH DP downtube battery with Samsung 21700-5000mAH cells:
Controller (Tongsheng 15A) is integrated inside the battery base:
Colour VLCD10:
Throttle kit if ordered:
Prices
Prices include UK mainland shipping.
Thank you for reading!
It's so simple!
Woosh hub kit with torque sensor
Tongsheng Aikema 85TS torque sensor kit with rear hub motors. Convert your bike easily into an electric bike in record time.
Colour VLCD10:
Prices
- 85TS kit (motor wheel, LCD, battery base but without battery) £300.
- Complete 85TS kit with 36V 20AH battery and charger (range about 75 miles from a full charge): £549
- Optional throttle kit (4 in 1 Julet cable, sensored brake levers and the throttle) £20.
