I have a Tadpole config recumbent trike sitting at home doing nothing much ( 2 wheels front ,1 rear), easiest way of converting it would be to put a rear hub drive into it, which I don't want to do,
Had a think about it , there are 2 options , it has 20'' front wheels with drum brakes ,bung a 2 front hub drives on to the chassis with disc brakes, a potential problem is that the wheels are simply bolted , not mounted on a axle as such, works fine tho' this would give me 3 wheel drive with the rear wheel being the original chain driven one .
The other option is to fit a bottom bkt motor ,the trike has a chainset mounted on a boom with a very long chain to the rear it takes 2 1/2 chains, but it has a further bottom bkt assembly under the seat as part of the frame ,which is threaded and blanked off ,this may be the best place to mount a ctr motor. maybe it would be possible to put a crossover drive ala Tandem, from the front to the under seat motor,I have spare bits to do that .
Do any of self builders see problems doing that?
Or maybe D8veh
Another thought is to put 5 , yes FIVE motors onto it, one in each wheel and 2 centre motors, should pull like stink but maybe not get very far!
Or maybe D8veh
