Are you sure it's 48v? I've only ever seen that format in 36v (the shorter version being 24v), like
this one where 36v/10.4Ah cells already fill that case. Would 48v/10.5Ah even fit? Generally, the higher the voltage in any given format you get less Ah capacity in the same physical space.
EDIT: I've just seen you're running several threads trying to convert your 20" Dawes Falcon folder to run on 48v. It might have been better to confine your project to just one thread so that so we can follow the complete story rather than individual bits of it. I think you may need to find a different/larger battery style/carrier for rear rack mounting at 48v.
