Do you already have the Burisch controller without speed limit. If not, you'll need a new controller to do any upgrade.
An easy starter is to upgrade only your battery to 44v. You can do that by adding a 2 cell booster pack or by replacing the battery with 12S lipos. A 36v controller should be able to take it. That would give you 20% more torque and speed.
Another step with or without the battery upgrade is to solder 30% of the shunt in the controller. That will give you 30% more torque, but it would be best to get a better battery do do that.
If you want a very significant step up in power, a BPM motor and one of those frame mounted batteries with the included 20 amp controller, LCD, etc from BMSBattery could make you go pretty fast with good hill-climbing too. You have decide on battery voltage and motor RPM to get the speed and power you want.
All the ancillary stuff like throttles and PAS are standard and will work with any system, except that the LEDs on the throttle will indicate wrongly if you have them
