36v nine pin compatibility
Bobby
Mar 10, 2020
Recently bought a 9 pin 36v replacement hub from China. Was wondering if it will plug and play on my existing Dillinger 36v street legal controller . And if not, can I cut and match colors on Julet plug to make it compatible? Thank you and aloha
8,842
Hubs using a 9pin Julet use a standard pin sequence ( at least the ones I have tried ) of know brands, this includes Yose, Bafang, Aikema & Mxus. If your controller has the matching female 9 pin Julet it should be plug and play, test it works under PAS before you try the throttle.
Reactions: Bobby
