36v Battery repair - Head scratcher ?
KirstinS
3,224
899
Brighton
Hi all,
I’ve got an old style bottle battery 9ah 36v that is misbehaving, not taking a charge properly. I’m getting 32v out so lost 10v from full
I opened her up and measured the voltages across series via the 9 pin balance lead that goes from the cells into the BMS. I got some very odd results that I can’t understand
Between pin 1 and 2 = 4.17v
2 and 3 = 0v
3 and 4 = 3.9v
4 and 5 = 3.95v
5 and 6 = 4.1v
6 and 7 = 3.8v
7 and 8 = 4.15v
8 and 9 = MINUS 10.8v
What on earth is going on here ? I tested and retrested using back, front and top of the balance plug as test points for each pin. Same everytime
It looks pretty clear there is a dead series between 2 and 3 but what on earth is going on between 8 and 9 to get minus 10.8v ??
Any help appreciated
Kirstin
trex
7,703
2,671
blown FETs at the output?
Reactions: KirstinS
KirstinS
3,224
899
Brighton
But the balance lead comes directly from the cells. Each series should be 3.6v nominal
So why one reads minus 10.8v rather than plus 3.6v is the question as it is pre BMS
trex
7,703
2,671
bottle-bms.jpg are there two groups of balance leads on your BMS?
mfj197
553
160
Guildford
Yes, surely a balance lead from a 36V battery (10S) should have 11 contacts, not 9? Unless the balance board takes the end points from the main +ve and -ve from the battery. Is there any way of knowing where the balance wires actually are in the batter pack (i.e. tracing back between cells 1 and 2, 2 and 3 etc.)?
KirstinS
3,224
899
Brighton
no trex , just the one 9 pin
I can take a photo when I get home later
It is a Panasonic celled one from 8fun
KirstinS
3,224
899
Brighton
Yes, I think this is how it works on this bms
