3000w e bike no throttle?
Cam3roon2k41999
120
Hi guys. I recently purchased a 3000w 72v motor kit and it came with the SW900 Display I asked the seller what displays are compatible and he said the UKC1-18 is. So I purchased one of those and there's no throttle input at all everything else looks like it's working apart from throttle but I don't have a PAS installed any ideas on what's wrong? I also checked the settings and there's no drive mode option thanks for any info.
3,994
How does it look like its working if you don't have a throttle or pedal sensor to work it.
The throttle connects to the controller, not the LCD.
8,841
I expect the display turns on.
Cam3roon2k41999
120
Yes the display turns on and I have a throttle connected to my controller but no pedal assist but as soon as I connect the new display (UKC1-18) throttle doesn't seem to work?
8,841
Display may not be 100% compatible or a setting not enabled ?
Cam3roon2k41999
120
Not 100% sure to be honest it's the 3000w kit from solos bikes if that makes any sense and all it says about controller is its a 60a smart controller means nothing to me lmao
