28"(700C) Yosepower hub motor spokes
bikerbob21
Dec 28, 2021
Hi folks, I was wondering if anyone could point me in the right direction to buy some spokes for a 28"(700C) Yosepower rear hub motor?
Here's the link to the actual kit. It looks like 13G spokes are the suitable ones and from measuring them they look like they are around 245mm in length. A few of mine have fallen off from the back hub motor wheel. Had a brief browse through Aliexpress and they have a few options there but wanted to check here with the experts first. Any feedback is appreciated.
8,517
The wheel needs rebuilding properly, it is best to use 14g spokes which have more give in them and should not snap so readily. 13g built wheels tend to be very patchy when it comes to breaking spokes.
Unless someone can give a definitive answer remove a good spoke and measure it properly from the threaded end to the inside of the bend and add +1mm.
Reactions: bikerbob21
8,517
The issue is finding a good wheel builder who will do a motor wheel.
I have had great success building my own, the first couple I used to get the odd broken spoke. Since those first forays into wheel building I see no broken ones more so since using a tensionometer and Sapim strongs.
Reactions: Jodel
Scorpio
370
164
Portugal Algarve (temporary)
Hi, I built a 29/700C rim onto a Yose hub, lesson learned for me are the spokes are different lengths on different sides (the drive side is shorter than the non-drive side).
The length you need will depend on the rim diameter, which will be different to mine.
