26 wheel. Which one?
Wayners
409
89
55
Gloucester
Hi
Ive decided to buy a new rear wheel.
26 inch. V brake. 6 speed freewheel.
Would any wheel that takes a freewheel work ok?
I've looked online ( not very hard I admit) but I can't find the answer.
3,150
Hi
Yes, any one should be OK. There are two types of axles - bolted on ones and quick release. They're interchangeable, but you need the Q/R skewer to clamp the Q/R wheel. The Q/R axle is 9mm dia with a hole through the centre for the skewer. The bolt on type is 10mm and solid. If your bike has the Q/R type, you might have to files the drop-outs a bit to get the solid axle in.
Reactions: Wayners
Raboa
786
297
52
Do you know the size of the gap between your rear dropouts? Mountain bikes are usually 135mm or bigger depending on fixture method.
Wayners
409
89
55
Gloucester
I think its standard width and I have a quick fitted ATM. Originally it was nut and bolt which I prefer. Quick release don't sit so well I find as every time I remove wheel the quick release never goes back in the same place.
Az.
2,044
903
Plymouth
It never happened to me. Wheel always fits exactly as it should.
If I were you I would check Facebook and Ebay within 10 miles radius. It might be cheaper to buy entire bike than just a wheel.
Reactions: Peter.Bridge
3,150
Or go down to the tip. There are always loads down there. One time when I wanted a cheap bike as a donor for conversion, I asked the scrap men to look out for one. A couple of days later, there was a knock at the door and the scrap man was standing there with a new looking catalogue bike for £10.
