Having had mixed successes so far, I'm now thinking of electrifying my recumbent bike.
It's a long wheel base Burley Limbo, with a 20" front wheel and 26" rear wheel.
I realise the traction on the front wheel will be much less than the rear as it has so little weight on it.
Never the less, I would prefer to fit a front hub motor as I don't want to lose any of the gearing range in the nine speed hub.
I've so far converted a 250w 36v geared front wheel 700c hybrid, and a 750w 36v direct drive 26" rear wheel mountain bike.
For this project, I like the idea of a direct drive for quietness, but don't want the drag when pedaling with the motor off.
I've had a look around, and I'm wondering what is the highest wattage 36v front motor with planetary gearing and dragless freewheeling ? Would it be 350 watts ? This Ebay item is a 36v 350watt front wheel kit for £239.26 bin Latest 36V 350W Front Wheel Electric Bicycle Conversion Kits with LCD Display | eBay
My big concern is that if the same motor is supplied in 20, 26 and 28" rims, then would it be undergeared in the 20" size ? Or do they do something inside the motor ? Would I still get 15 to 18 mph ?
It's from Conhismotor, who I'm a little nervous about as well, as I still have their controller unit (and replacement), neither of which have I managed to get working at all.
So, (still waffling away here, sorry), can anyone recommend any alternatives ? The main object is to have the option of electric assist on the recumbent, hence using the front wheel, which could be quickly replaced with the standard wheel.
350watts might give me a slight edge over the 250, and yet still be completely dragless.
