110v conversion for 36v Macallister battery charger?
keithb
Apr 21, 2015
We have two 5yr old nano bromptons which we have routinely taken to the US by plane using the original 4ah batteries supplied which have now died
Bought 36v 4ah Mac batteries and charger but latter needs 220v
Any ideas on modifying charger for 110v input?
KirstinS
3,224
899
Brighton
Two suggestions for you
1. Use you old charger (any 36v lithium charger can charge any 36v lithium battery, ) just cut off the connector and solder a new one on. Maplin stock most. Post photos of your old charger and new battery socket and I'll help, no worries
2. Buy a US to UK step up converter, something like
https://www.google.co.uk/search?rlz=1CDGOYI_enGB593GB594&hl=en-US&biw=320&bih=492&tbm=shop&ei=4kw2VaXyDo2v7AbDvoHYBw&q=110v+to+240v+step+up+&oq=110v+to+240v+step+up+&gs_l=mobile-gws-serp.12..41j0.37046.38426.0.38861.11.10.0.0.0.9.488.2632.0j2j6j1j1.10.0.msedr...0...1c..64.mobile-gws-serp..10.1.240.7KZLni1ZmJA#spd=4827237109407252818
KirstinS
3,224
899
Brighton
Actually I am assuming that both your old and new packs are lithium, 36v and have a BMS for option 1 to work
keithb
Apr 21, 2015
Hi Kirstin
Thanks for all the replies!
I want to avoid a step up transformer as they are so heavy
May go with a 12v inverter as I will be driving anyway and probably lighter
Thinking a trying out original charger but still not totally convinced that all Li chargers are equal!
KirstinS
3,224
899
Brighton
If you can get away with a 150w it's much smaller
A powerful enough 12v inverter seems even bigger ?
You are right - not all equal but as long as lithium specific and rated at 36v ( so 42v output) and you test with a multimeter should all be ok
