Where an I buy a HL xl charge port?
8,839
You may have to diy bodge it Kirstin and doubt you will get a grommet insert for it without robbing a broken case.
You could use a bit of epoxy fibreglass sheet (0.5mm - 1mm thick) you can buy it in yellow or Black, then glue it in place with Gorilla epoxy on the inside or outside of the top half of the case. Drill a small hole in the middle and mount a small dc panel mount charge port in place.
Epoxying on the outside and slightly over size will be a bit better to prevent moisture ingress.
KirstinS
3,224
899
Brighton
I did think that tbh and but always worth an ask. Some on here (like your good self) have an uncanny knack for finding things on the Web or in the shed!
3,994
Try Jimmy. Maybe he's got a smashed up case somewhere.
Failing that, you can get the jack socket from Ebay and mount it to any flat piece of plastic that you can glue over the aperture. Get them as a pair so they definitely fit.
Reactions: KirstinS
8,839
A bit of luck to find it in the car K, saves one headache.
