The next event in the calendar which is in less than a weeks time is going prove interesting with currently no bike to ride. I'm not holding out any hope that the BH battery will be back before the event, so with some reluctance I have decided that my only option is to use the hybrid Haibike. I have already ridden some of the course, and know that the bike isn't suitable, and have read that whilst cyclo cross bikes are actively encouraged, for this event they are not recommended.
I started to prep the bike last night, and have stripped off all the weight that I can, but it is still a hefty 2.5kg heavier than the BH. Even the OE side stand weighs 275g. It is certainly a lardy and heavy bike!
I swapped a few parts over from the BH, but have held back just in case. I also have a set of cyclo cross tyres for the 700c wheels on there way from Germany, so hopefully they will arrive in time. Tyres are often less than half the price of UK supplied ones, so it's always a no brainer when it comes to looking elsewhere to buy them.
The biggest issue with using this bike, are the dire OE forks. They are mediocre at best on the road, so off road use isn't going to improve the ride! I also suspect that most of the bikes extra weight is in them. The frame is also a bit on the large size, which is fine for road use, but isn't going to be so great off road. The Magura MT 2 brakes are also another aspect which don't live up to much, but there again, at least they will mean that I'll be going slower down hill, so hopefully won't wreck the wheels.
The last downer is that I suspect that the usual friendly welcome won't be so good this time with an in your face mid drive motor and external battery on display. Along with the louder motor noise, my usual stealth and unassuming bike approach, is blown big time. Hub drive and integrated batteries certainly help when it comes to being low key.
The one and only advantage that I can see from using this bike, is battery duration. At least that is where the Bosch scores.
Anyway, here are the event details, which I'll update again after the event.
http://www.ukcyclingevents.co.uk/events/devils-mtb/
Unless it proves too much for the bike, I have opted to do the epic route.
The video... This is the first year that this route has been used, so previous years event videos aren't available.
