September 23, 20232 yr It's been lashing down and my original plan to attach plastic bags over my feet failed. Well it works but not ideal tbh. I've been looking at options and I'm not messing about with expensive overshoes ect. I've decided to wear wellies:D I can drop waterproof trousers over the top. If they rub I'll buy some half height wellies as cheap enough. I seen some waterproof riding socks in Aldi today although sold out in my size. They look good. How do people keep feet dry especially in winter when riding?
September 23, 20232 yr Not cheap but waterproof socks.... I have pairs of "Sealskinz" and "Otter" brands. They really do work, but be sure to get the long ones rather than the ankle versions (Rain runs down the inside and you end up paddling not pedalling)... TTFN John.
September 23, 20232 yr Author I've got locker at work ( several tbh but don't let on). I've actually got access to showers and a drying room for wet stuff. Watching the bike commuter videos on YouTube, I can't see what other are doing to Keep feet dry. I guess they swap out shoes and socks at work. I know some like myself are lucky to have facilities at work, and the drying room is very good. Winter is coming and it's on my mind as I only started riding in June this year. Winter will be a learning curve for me as Im determined to stick with my bike. I'm not going to give in to bad weather
September 23, 20232 yr Wellies are fine for shortish trips. My commute is 20 minutes max, offroad wet and muddy in winter, and they do fine. Longer trips I use Crocs and dry socks when I arrive!
September 23, 20232 yr Author I'm about 20 mins ride. Small section through woods so puddles and mud. Got a unexpected slide going last week which got my heart going through the muddy bit. Crocs though. Don't your feet get cold?
September 23, 20232 yr rub dubbin into the seams of your leaky footware plastic bag 'oversocks' will work for leaky footware but you need good quality un punctured polythene bags, any hole and water will seek your feet and old carrier bags are not upto the job.
September 23, 20232 yr It's been lashing down and my original plan to attach plastic bags over my feet failed. Well it works but not ideal tbh. I've been looking at options and I'm not messing about with expensive overshoes ect. I've decided to wear wellies:D I can drop waterproof trousers over the top. If they rub I'll buy some half height wellies as cheap enough. I seen some waterproof riding socks in Aldi today although sold out in my size. They look good. How do people keep feet dry especially in winter when riding? There are all sorts of expensive things you can put on your feet, but none of them are as good as a cheap pair of wellies - same on a motorbike.
September 23, 20232 yr Crocs though. Don't your feet get cold? They normally have their noses out of the water, so if you look carefully, you can see where they are and steer around them so that they don't get a chance to bite. It helps if you keep your speed up a bit too. If they do bite, try poking them in the eye. It sometimes makes them let go before they drag you under.
September 24, 20232 yr Wellies are fine for shortish trips. My commute is 20 minutes max, offroad wet and muddy in winter, and they do fine. Longer trips I use Crocs and dry socks when I arrive! I agree. when I used to commute and it was rainy I used wellies for an about 1/2 hour trip each way and didn't find them a problem. I was usually on-road if the weather was bad. I've not tried Seal Skins for riding. I tried for walking and they fairly quickly got a small puncture; that allowed my feet to get wet and made sure they stayed wet.
September 24, 20232 yr Crocs though. Don't your feet get cold? Thick woolly socks seem to do the job in the wet. Multiple pairs when really cold. One trip back in February I wore three pairs, but it was sub-zero most of the day. West coast of Scotland, we rarely have wet and really cold due to the Gulf Stream.
September 24, 20232 yr Author I'll report on how it works out. I bought a size smaller as fitted nice vs flopping about. I'll be peddling not walking. Be interesting to find out if it works for me
September 24, 20232 yr It will keep your feet dry, but it won't be comfortable. The problem is that your feet aren't comfortable when wet. It's a case of whichever unconfortable is the worse. One other thing. Wellies can be a little cold in the depths of winter, like when riding in the snow. I think the rubber must be a bit conductive. the solution is easy: get a pair that are one or half a size bigger and wear thick socks, then they're warm and waterproof.
September 24, 20232 yr Author Well I've fitted old unused foam insert and been wearing wellies for last 3 hours. Been on a bike ride with my son and all good. £15 well spent. Can't say the same for the bacon bap and coffee X2 in town for £19.90. Was not nice.
September 25, 20232 yr Have you looked at Derri Boots they are waterproof and lined, used to use them many years ago when I had a motor scooter in the UK, never had cold or wet feet in the winter.
October 8, 20232 yr By commuting on bike you are saving tens of thousands. Treat yourself a little, you really deserve it £52 with OUTLET20 code: https://www.houseoffraser.co.uk/brand/adidas/terrex-ax3-gtx-hiking-shoes-mens-182303#colcode=18230303 £45 with C3357DS5 code: https://www.reebok.eu/en-gb/shopping/ridgerider-6-gore-tex-shoes-19727459?clickref=1011lxQZSI59&utm_campaign=reebok_ptz_gb&utm_medium=affiliate&utm_source=drytinder
October 8, 20232 yr By commuting on bike you are saving tens of thousands. Treat yourself a little, you really deserve it £52 with OUTLET20 code: https://www.houseoffraser.co.uk/brand/adidas/terrex-ax3-gtx-hiking-shoes-mens-182303#colcode=18230303 £45 with C3357DS5 code: https://www.reebok.eu/en-gb/shopping/ridgerider-6-gore-tex-shoes-19727459?clickref=1011lxQZSI59&utm_campaign=reebok_ptz_gb&utm_medium=affiliate&utm_source=drytinder Would it be better to send the money you saved to starving Africans, who need the money for food rather than give it to global corporations, who exploit them to make profit, which they use to finance tyranny on you?
October 8, 20232 yr Would it be better to send the money you saved to starving Africans Well... it depends from point of view. It would be better for starving Africans, but wouldn't be better for Wayners. Personally I prefer to help African children living in poverty in UK only because I can direct help personally and ensure 100% goes to those in need. Don't trust charities at all. ...but I don't recall you taking a moral stand against corporations, misery caused around the world by British Empire or corporations in China. Would like to hear more if you are willing to allocate some time.
October 8, 20232 yr Well... it depends from point of view. It would be better for starving Africans, but wouldn't be better for Wayners. Personally I prefer to help African children living in poverty in UK only because I can direct help personally and ensure 100% goes to those in need. Don't trust charities at all. ...but I don't recall you taking a moral stand against corporations, misery caused around the world by British Empire or corporations in China. Would like to hear more if you are willing to allocate some time. I like most of the Chinese and African people I've met and people from many other nations. I don't like most of the corporation bosses I've met. It's as simple as that. I have also met many MPs and councillors. I didn't like any of them.
October 8, 20232 yr I like most of the Chinese and African people I've met and people from many other nations. I don't like most of the corporation bosses I've met. It's as simple as that. I have also met many MPs and councillors. I didn't like any of them. Fair enough... I think most of us share same feelings on this subject, but if we start factoring ethical aspect into buying things we might end up living off grid and foraging somewhere in Montana. Is buying shoes less ethical than ebike components from China? I am not sure...
October 8, 20232 yr Fair enough... I think most of us share same feelings on this subject, but if we start factoring ethical aspect into buying things we might end up living off grid and foraging somewhere in Montana. Is buying shoes less ethical than ebike components from China? I am not sure... The way I see it, the more frugally you use your resources (mainly money), the more you have left to help people that need it. If you buy expensive stuff, all your money goes to profit for corporations. Some people have very hard lives. If you were a Ukrainian, you'd probably be dead by now. If not dead, you'd probably be sitting in a trench somewhere saying your prayers every hour. The normal people in Gaza and bordering parts of Israel are in serious trouble. They won't be going shopping or for a Sunday walk in the countryside. None of it has anything to do with them. It's just the agendas that our global controllers have. They don't care about the little people. They're all paid for by corporations.
October 8, 20232 yr The way I see it, the more frugally you use your resources (mainly money), the more you have left to help people that need it. If you buy expensive stuff, all your money goes to profit for corporations. Some people have very hard lives. If you were a Ukrainian, you'd probably be dead by now. If not dead, you'd probably be sitting in a trench somewhere saying your prayers every hour. The normal people in Gaza and bordering parts of Israel are in serious trouble. They won't be going shopping or for a Sunday walk in the countryside. None of it has anything to do with them. It's just the agendas that our global controllers have. They don't care about the little people. They're all paid for by corporations. I hear what you say and agree with most of it, but I struggle to apply it to context of this thread. £50 for goretex shoes is a really good value for money (unless you are able to show us a better deal).
