Kona Stinky UK - MXUS, Adaptto, 20s, 19" Pro Wheel
Sacko
281
13
Kona Stinky Large Frame
Custom designed/machined Torque Arms
Custom deisgned/machined battery case
Pro Wheel 19” JRH rims
2.5” x 19” matching tyres
Shimano XTR hydraulic front brake
Hope rotor
DMR Convertible hub laced with 13g JRH Sapim spokes and matching nipples
MXUS 4t laced with black 12g spokes
Adaptto Mini-e controller
BMS
Eaton PSU
20s 10ah Hardcase Turnigy Lipo
DC converter (output 12v)
Magicshine rear light
12v-90v front LED light (both lights are switch on with a key fob, wireless switch)
Marzochhi Bomber forks (require service shortly)
Magura throttle
Variable regen with Wuxing lever
On/Off switch handlebar mounted
Max speed - 48mph (Hit 50mph regularly in the right conditions)
Range – 10miles +
Only selling as we are relocating and will not be able to commute to work anymore on the bike (never been off road)
£2000
Sacko
281
13
Thought I would mention charging in a bit more detail.
The cells are managed by the Adaptto Battery Management System. The system is fully customisable using the display; seeting LVC + HVC, monitoring the cells, capacity limits etc.
The cells have been well cared for as you can imagine, and are as new.
The charger itself is a single plug, that plugs into the side of the bike using an expensive Eaton PSU (Was £150 delivered). IMO this is the best charging setup available at the moment.
