Good afternoon, I am new here so please be gentle, Before i posted i searched for my situation and found quite a lot of advise on hall sensors for a similar issue to what i am having but i think i need to explain how i got to mine.
I built my own kit, including batteries, rode it for two weeks even in the heaviest of rain with no issues.
i must admit that the packs and contoller are just slung over the centre bar in a rucksack which means it has the chance to move about, not ideal but needed to make a housing for the whole lot.
back to the issue.
I had just been on a journey, only about 8 miles this time at 250W setting and when i went to put extra throttle on it to get up the last hill, the motor just juddered and stopped, when i pull the throttle it just jerks forward and stops.
luckily i was 5 mins from home so no big issue but it meant i had to work out the issue quick as its my daily commute to work...
i took the batteries and controller out of the bag and found that the yellow phase wire was very hot, that hot it burnt the tip of my finger... this is obviously due to me not tightening the nut up fully and it arcing...
this in turn had melted through the black cable on the Bike light connector.
Now i am not sure if this has blown something in the controller so tested all the Mosfets and they seem to be giving almost equal results. not exact so i may change those.
I tested the Hall sensors and found that i have on the green sensor a constant 2.25V
my next step is to order some hall sensors and mosfets but the question is, do i have to match the sensors to the ones already in and if its gone so quick should i get better quality ones.
is there a standard hall sensor? or do they match the controller?
the kit i sued was the VoilaMart 250W/1500W 48V one sold on ebay... obviously its one of the cheap chinese controllers and the next question is so that i am legal on the road can i buy one of the cheap 250W controllers from ebay and attach that to the motor once i have replaced the hall sensor of course
Cheers for any advice that you can give me.
back to the issue.
