I have a TGA 20'' folder, an early mid drive bike with crank freewheel. The motor is a 90 degree worm drive primary (about 50% efficiency, 24v nominal, draws 35A peak & 24A normal.) This needs two 18Ah SLA's so not ideal. The rest of the bike is not bad with hub brakes. I looked into a Cyclone motor but found this unaffordable. I then found this
https://endless-sphere.com/forums/viewtopic.php?f=26&t=15704&start=300. Pic is about halfway down
What I really want to know is how has he mounted the sprocket on the motor. If bolted directly to the alu motor casing, then there is a freewheel built in to prevent pedals 'back driving' the motor?. A fixie sprocket screwed on (if a rear motor) would tend to unwind off unless somehow pinned to the casing?. I would want to go to 36v as the other stuff I have is this. Looking at about 20 Nm & 201 rpm as adequate Would give me 34 Nm in lowest S/A gear & a 6 to 15 mph range. Anyone on here who has opened any small motors - to know if there is any room to bolt through to an end plate. & if so which motor. You might say buy a mid motor kit, but these not affordable for me. (Bike rescued from the local tip, would like to re use)
