1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
GSM / S12S / LCD3 / 36V - error code 03-INFO
Discussion in 'Electric Bike Conversion Kits' started by pn_day, Mar 21, 2018.
  1.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Cool tip - I was just about to take crank arms off and make a mess - you must have done this before!
    • Agree Agree x 1
  2.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    PAS mode works with an external sensor - or at least the motor comes on when twiddling the PAS magnet ring around in front of the sensor.
    I'm confused - it was also pulsing on the same signal line, exactly the same as the internal PAS.
    Are there any other diagnostic ideas that might be worth trying?
    It seems a waste to fit an external PAS of there is an internal one which is producing pulses.
    #22 pn_day, Mar 22, 2018
  3.
    Woosh Trade Member
    6,265
    942
    you need to make sure that only 3 wires are connected to the internal PAS: ground, 5V and only one Hall wire, in this case, yellow. The other Hall output (blue) should be left unconnected and insulated.
    Check also when spinning the cranks in reverse (anticlockwise). If it starts the motor, then one of the registers on the S12 has a wrong value.
  4.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Wiring is as you say, with 4th wire being unused and insulated.
    Cranks backwards does not work either - pedalling forward or backwards fails to initiate PAS using internal sensor.
    #24 pn_day, Mar 22, 2018
  5.
    Woosh Trade Member
    6,265
    942
    I am out of suggestions :(
    Any one has a better idea beside using an external PAS?
  6.
    Nealh Pedelecer
    4,693
    1,074
    Lcd3 is only KT compatible, parent company is szktdz.com. Most probable the moon pas isn't recognised for some reason., may be there is a small pcb for the pas in the motor ? If you have tried all C1 options then you will have to use an external pas.
  7.
    Woosh Trade Member
    6,265
    942
    Phil, was it working before with the same controller?
  8.
    anotherkiwi Pedelecer
    Jan 26, 2015
    5,943
    1,698
    Mine worked OK with the KT controller but it also worked when pedalling backward and it had a lot of run on when you stopped pedaling. I have forgotten the setting it worked best on because I fried it pretty quickly by plugging it into the speed sensor plug by mistake... :oops:
  9.
    Nealh Pedelecer
    4,693
    1,074
    My pas with lishui controller works both ways I have to remember not back pedal even an eighth of a turn.
  10.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Hi all,
    Thanks for all the help.
    It sounds like I'll have to use the external PAS then - not to worry.
    Just to clarify, I have not been able to get GSM internal PAS to work at all with my controller (using all values of C1 from 5 magnet up to 12 magnet). I was able to use an external PAS.
    Thanks again for all the helpful feedback and for your input. I now need to remind myself of how to fit an external PAS :)
    Cheers all,
    Phil
  11.
    d8veh
    d8veh Pedelecer
    Oct 12, 2010
    21,708
    4,709
    There's a specific setting for the type of PAS sensor on a KT controller. It's C1. Yours is set to 03, but for a 12 magnet PAS it should be 06 or 07. I don't understand why you didn't set it correctly. can you explain? If you don't have 12 magnets, you should try all the other settings - both forward and reverse.
  12.
    Jan 26, 2015
    5,943
    1,698
    IIRC there are many more magnets in the GSM I think it may be the same PAS as the bafang BBS01.
  13.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Hi d8veh.
    I've got an older version of the controller (S12S) & LCD3 which only has options up to C12 (I think newer versions go up to C14).
    In the version of the manual that I have, it states the following values for C1
    00 - 5 magnet sensor
    01 - 8 magnet sensor
    02 - 10 magnet sensor
    03 - 12 magnet sensor
    Sounds like my version of the manual may be suspect - can you send me a link to the newer version please?
    Based on this I'll do some more testing at the weekend with all values of C1 from 00 to 07, pedalling both forwards and reverse.
    Thanks again for the input - I would like to avoid using an external PAS if I can - less to get knocked (this is all buried in the bowels of a velomobile - an Alligt Alleweder A4).
    Cheers
  14.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Hi all
    Thanks to d8veh for the pointer. I found a newer version of the manual for the KT-LCD3, and tried all the settings for C1 thus had.
    Settings 5, 6 & 7 all work, with 6 being the best. According to the newer manual, this therefore means that the PAS gives 'reverse' pulses.
    So I now have PAS working with the internal PAS - thanks to all for the help.
    Cheers all
    • Like Like x 1
  15.
    Woosh Trade Member
    6,265
    942
    that's good news!
    So C1 = 6
    Phil, can you post your LCD3 settings here for reference?
  16.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    My settings for reference
    S12S with filed shunt bringing max current to approx 16A
    GSM crank drive
    KT-LCD3
    P1 160
    P2 1
    P3 1
    P4 0
    P5 12
    C1 06
    C2 0
    C3 1
    C4 0
    C5 08
    C6 1
    C7 1
    C8 0
    C9 0
    C10 n
    C11 0
    C12 4
    • Like Like x 1
  17.
    d8veh
    d8veh Pedelecer
    Oct 12, 2010
    21,708
    4,709
    We love happy endings - even better when they can help other people.
  18.
    pn_day
    pn_day Pedelecer
    Jul 26, 2013
    159
    29
    St Andrews, Fife
    Thanks again to all who contributed.
    The moral of the story is to try all the options, even the ones that aren't documented in the manual!
Share This Page
