DNP Epoch Freewheels..and gearing question
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
Curiously, this company seems to be the ONLY manufacturer of 11T-28T freewheels in the world but I'm seen some people on endless sphere saying they're rubbish quality.
I was wondering if anyone has heard of the company or has anything good/bad to say about them? The freewheels are made in China I think and the few sites that sell them (in the States) say they are nickel plated. They come in 11-28 to 11-34.
It's strange how you can't buy freewheels in UK from any of the big manufacturers for anything smaller than 13 or 14T. Maybe it's just because cassettes have taken over and less freewheel manufacturers or less demand for them, as I noticed there's plenty of 11T cassettes from the likes of Shimano etc?
If you wanted to substitute 11T for 13T how would you determine what chainwheel to use, if you already have 54T with 11T cassette, if you wanted the same gearing on a freewheel of 13T or 14T?
Old_Dave
1,211
Dumfries & Galloway
Divide the Chain wheel by the cog = x
Times x by the 13t to see what the equivalent chain wheel would be needed (or by the 14t)
There may not be an exact size chain wheel available so go for the 'as near as dam it size'
So 54T with 11 = 4.9
13t equivalent = 13x4.9 = 63.8
14t equivalent = 14x4.9 = 68.6
You can still occasionally get the Shimano Megarange free-wheel with 11T top. I managed to get a couple a few months back, Looking at it, it doesn't look as good as a DNP, but it has a replaceable top gear, which I hope is the same as a cassette one but probably isn't. I think that the main reason the DNP one gets slagged off on ES is because it's not as good as a quality cassette. I've found nothing wrong with them.
Don't waste your time with 13T or 14T free-wheels on a folder. The cheapest and most convenient option is still a 11T DNP one, otherwise you need a 60T chain-ring if you can find one.
When yoou electrify a bike, yoou normally need to raise the gearing because of the help you get from the motor. Any lowering of the gearing will just spoil the ride.
morphix
2,163
119
Worcestershire
Check this out...£291 bid for a Shimano 11T freewheel which would have cost what, £30-£50 a few years back before they stopped making them? Crazy! That's how rare they're becoming I guess.
Shimano 7 Speed 11 28 Hyperglide Freewheel "Mega 7" | eBay
I just bought a DNP Epoch 11T-28T and ended up getting from China in the end for $32. It was either that, or get a Sturmey Archer 13T-28T..but when I saw the price of new chainwheels/chainsets I decided against it.
I just checked mine. It isn't Shimano after all. It's different to my other DNPs and has "Mega" written on it, which is what threw me. Disregard everything I said in the above post.
morphix
2,163
119
Worcestershire
I'll see how I get on this with DNP I'm hoping its new stock rather than old which seemed to have some QC issues according to some users (noisy transition, 5th or 6th gear not working) and premature wearing of teeth.. I noticed some discussions on Endless Sphere with one of DNPs Canadian sales reps who says these probs have been been straightened out after listening to feedback from customers.. I had a look at their website (DNP in Taiwan) and they supply only to the trade in batches of 26 freewheels.. since they're so scarce in UK I've asked for a price and might offer them via eBay for eBike builders if mine checks it out ok..they have a good range of gears available too :)
Fordulike
3,802
1,538
I've been running a DNP 7-speed 11T for about 1000 miles.
Not sure if I have the new type though.
I would say that it is slightly noisier than Shimano equivalents, but not by a great deal.
One potential problem though, if fitting to a hub motor, is the lack of support at the 11T end with the hub axle.
There's quite a gap between the axle and the inside of the cog.
If you pedal hard using the 11T ring, this can create a lot of stress pressure on the side casing of the hub motor.
Mine ended up cracking the side casing (see picture) and because I was pedaling off the seat, nearly threw me when it went.
After replacing the cover, I learnt to adjust my riding style. Letting the motor do a lot more of the work and no more hard off the seat pedaling.
Someone on Endless Sphere has found a solution, by inserting a tight fitting bearing into the end, to support the freewheel.
If you do choose the other route and opt for a 60 tooth chain ring, bicycle engineers Highpath Engineering supplied me one made by a French company. Highpath offer a range of them or can make to order.
morphix
2,163
119
Worcestershire
Was that expensive flecc? I've been looking at the cost of chain rings and I'm shocked how expensive they are, CHEAP ones are like £50 and some go to insane prices like £300!
morphix
2,163
119
Worcestershire
Why are chainrings so expensive! Freewheels look more complicated to make yet are much cheaper!
Yes it was, I can't remember exactly how much offhand but think it was something like £93.
£1.50 per tooth plus P & P! :(
Scimitar
1,772
40
I've come to the conclusion that only three gears are really needed on my bike anyway - and I still have the three chainwheels up front, which I intend to reduce to a pair.
If the 11toothed cog will screw further down onto the the freewheel body, I'd be inclined to shed some of the other cogs and reduce the leverage on the casing that way. Remains to be seen how achievable that is, for some of the freewheel designs preclude that, from what I see.
Scimitar
1,772
40
These big chain rings are one-offs or small batch production whereas the freewheels and cassettes are turned out in their millions. Freewheels, less so, nowadays.
morphix
2,163
119
Worcestershire
That's an interesting thought Scimitar I guess if you don't plan to ride unpowered you only really need a very high gear (11T) for assistance and maybe something in the middle for mid-way assistance power level, and then a very low comfortable gear for unpowered emergencies.. maybe 24T or 26T. Less weight on the bike and redundant gears! I was initially going to do something like that myself and even considering single gear (11T) but after riding the Mezzo I just loved riding it unpowered and think I'd like to do that to keep fit.
Scimitar
1,772
40
I only use two gears anyway - 32T for taking away from a standstill and then whang it straight onto the 13T for cruising and back to the 32T when coming to a junction.
With two front chainwheels and three at the back I'd be covered for unpowered riding, because that gives a very good range.
When I had a 3spd bike years ago, I never felt the lack of gears - it did what it needed to do and got me around.
neptune
1,743
353
Boston lincs
This raises an interesting question. Is the trend mow towards cassettes, or freewheels? There is a guy who has a stall on the local market selling bike parts and doing a few repairs. He tells me that the trend is towards freewheels, but I am not sure if others would agree.
Scimitar
1,772
40
Freewheels were definitely on the way out until the Chinese re-introduced them to the West with their hub-motored e-bikes. It would be harder to adequately and cheaply engineer a cassette system onto a hub with a high degree of reliability, I would think.
Just look at how easy and cheap it is to obtain an 11T cassette cluster on ebay - compared to freewheels. That's really down to scale of demand and manufacture.
Even buying one direct from aliexpress is more expensive than I can find a cassette on the 'bay.
Aliexpress.com : Buy DNP Epoch 7 Speed Freewheel Cog 11 28T 7S speed For shimano system bike MTB cassette mountain xc from Reliable bike bicycle sports suppliers on Bike Bicycle Accessories Wholesaler(Free shipping)
That's the one I'll be ordering next week, I think. I'll have a go at reducing the cog count, too.
I don't think it's very difficult. A guy managed to bolt a cassette hub on to the side of a Bafang BPM motor in his shed after machining off the free-wheel. He sent it to Bafang, and they used it to develop the Bafang CST motor, which I'm just trialling at the moment. I don't know why it has to be so much more expensive than the BPM, because the rest of thr motor is the same.
8FUN¡¡Motor
