I'm sorry to hear that the Beastamatic is temporarily dead. I'm sure that it'll be alive and well again soon, but in the meantime its spirit will live on in the Beastamatic II.
Mine arrived today - much quicker than I expected. Here's what I got.
It took me about 20 mins to put it together. I was quite impressed by most of it, but it had one problem that need sorting: The front wheel bearings were miles too tight, so I set them right. I had difficulty adjusting the stem height because I couldn't loosen the hex screws at the side, but I managed to knock it up with a mallet after removing the locking screw underneath. The only disappointing thing was the rear drum brake, which means 160mm between drop-outs - much wider than all my spare motors, but, hopefully, if I smoke a motor, I can just change the internals.
Tomorrow, I will test it in standard form and see if I can get a measure for its climbing ability and speed on the flat.
While waiting for it to charge, I opened up the controller cavity, took out the controller and had a look inside. My first thought was how tiny it is, and it's rated at a mere 6A. Here's a picture of it compared to my 36v 30A controller.
Inside I found that the capacitors are rated at 50v. That's right on the limit for a 12s lipo pack, but should be ok for a 10s pack. What does anyone think. The FETs are 80NF70: 68v, 98A, 190w, so should be ok for quite an increase on their present situation as long as they can be kept cool. The regulator is a PJ317, which has an output od 1.5 to 37v and a differential between Vin and Vout of 40v. What is it's normal Vout - anyone know? NRG?
I need to get a new wattmeter/ammeter before I start modifying the controller, so that I can see the differences, so It'll be a couple of days before I do that.
Steps I want to try:
1. Solder shunt
2. 15amp controller mounted externally plus 36v battery
3. 15 amp controller and 44v battery
4. 15amp controller soldered shunt and 44v battery
5. Throw it off a cliff and claim the electric bike speed record at 150mph.
1. Solder shunt
