Cyclamatic Power Plus with 36v battery and controller
It's not easy to make suggestions without knowing what the issues are. Here's some to get you started in case I'm a FMR:
Leave the soldering iron on a bit longer to get more heat into the joint.
Make sure that you don't use full throttle until it runs correctly.
Never guess what wires do. If you're not sure, check them with a voltmeter first.
You have to get the correct hall/phase connection sequence, which isn't always colour to colour
Connect the ignition wire.
There's a lovely story behind the F....... mind reader, but I won't bore you now.
Reactions: Fordulike
dtg78
10
Can anybody send me a link to a site where I can buy a compatible 36v controller for the cyclamatic with a 36v battery please?
