CARRERA VENGEANCE
peter.c
1,612
493
thurrock essex
Whilst waiting for the parts for my build its going to be a few days before they arrive
I started looking at the pile of unused bits motor wheels etc IMG_20180815_165157.jpg and look what fell into my lap was only 2 min awayIMG_20180815_194032.jpg IMG_20180815_194044.jpg IMG_20180815_215920.jpg
peter.c
1,612
493
thurrock essex
The only bits left will be the frame forks seat post pedals and handlebar's the wheels are 29er now 9speed every bit has been leftover from previous builds :mad::rolleyes:;)
peter.c
1,612
493
thurrock essex
The bottom bracket meets angle grinder chain line now good in all 9 gears :)
Triangle battery pack in luna cycles bag done :rolleyes: reinforced with 20mm plastic conduit with dowel glued inside
hydraulic brakes 203 mm discs done, cut out on rear only
It is getting there will be finished before all the bits arrive for the zebop build
snail mail :(
peter.c
1,612
493
thurrock essex
Test ride went ok:) needs to go on the laptop keep current etc:rolleyes:
Will need to sell it to fund the zobop build
The luna bag works now the battery weight is suspended from the frame the 27ah triangle battery and the 350watt should be a good combination :DIMG_20180817_185914.jpg IMG_20180817_185833.jpg
PC2017
1,319
334
Scunthorpe
Its a beast - a lot of hard work I can only imagine, far too fast for me though - good luck with the Zobop build!
wheeliepete
2,047
757
Devon
Finished on ebay to fund the Zobop build bbshd and 52 v battery
Peter, don't forget to allow for the larger gear housing on the HD, 67mm min. from centre of BB to chain stay, or you will need more than asprin to crush the pain:eek:
