This post is part of a set of posts following my project to "E" my Brompton :
A. Wheel Building - Tongxin in Brompton wheel
B. Building a small A123 Battery Pack
C. E-Brompton First Ride/Tweaks
D. Taking a Tongxin motor apart
You may also like to check out daniel.weck's post here which covers the simlar use of Tongxin & Bafang motors and inpired me to give this a go.
A couple of related links as I was building
Throttle Controls
Connectors
Ok as promised here is my post recording my attempt to build a 6s1p (6 series 1 parellel) A123 battery pack. I will then use two of these in series to make up a 36v pack
Again a couple of points to make before I post :
1. *** WARNING/DISCLAIMER *** This post follows my progress. It is a personal project to see if I can make good use of this small light pack. These packs can carry and discharge high currents, so I in no way condone or recommend anyone to build them even after reading these posts. If you do its your choice and you are completely responsible. Not sure if this is the correct legal jargon but you get my drift RIGHT!
2. I am not an electronics expert but have built and used a lot of different battery packs of various types in my other hobby which is RC model planes and helis. So again any experts or anyone if you like, chip in with suggestions, comments & encouragement as you want.
3. Again I am not the first to do this its been done before a lot in the RC Model and Ebike environment. Freedom E also use something simular in their lightweight packs.
The requirement for me was to come up with a light small battery pack for my E-Brompton. A123 cells have been around since about 2006 when they first appeared in DeWalt drill power packs. Intially people stripped these down to scavage the 10 cells out of them. I won't go into great detail but will give you a few links to look at.
These mostly came from Daniel in some email exchanges but I have read many before myself :
Dissecting DeWalt 36V Packs (A123 Systems)
Youtube Video Dissassemble Dewalt 36V battery
Dewalt A123 BMS battery interface solution
Endless-sphere.com • View topic - Dewalt A123 BMS battery interface solution
Youtube Video - Soldering Cells
Note I am not a fan of soldering directly on to the cells, but some do.
The care and feeding of a123-based packs...
My choice was to either to get hold of a couple of DeWalt packs for disassembly, buy second hand used cells from Dewalt packs or buy new cells. As I wanted to test these packs the latter would not give me a clear idea of whether they work or not given that some cells would have been used so I have decided to buy new cells. The cheapest way to do this is to get them from Ebay from either HK or China. If you keep numbers down you can buy them cheaper without incurring import duty. Alternatively you can buy new ready made up 6s1p packs from here or packs made up from ex DeWalt cells from here
Again I did not want to go down this route as firstly new ones are expensive approx £70/6s1p pack and again the used ones could give me spurious results. Also at least if a cell fails in my packs I can take them apart easily knowing how they are built and replace it.
Ok so lets look at these cells. This is a sample of three that arrived yestday from Hong Kong
I am quite pleased with these and will be ordering 12 more for my two packs of 6s1p. They came well packaged and protected from shorting on the welded tabs.
So why get them with welded tabs ? Well as I said if you solder to the battery facing themselfs you can risk damaging the cells. For a tiny bit extra they will spot weld solder tabs on for you.
They are larger than I expected. I am use to using Sub C cells for my RC models here is a comparison of the two. The Sub C cell is a 3000 mAh NiMh cell. In fact I had thought of using NiMh cells in 3 packs of 12v connected in series. The problem is they are heavier and I would probably have to charge all three packs seperately. They do however go up to I think 4600mAh now so it certainly worth thinking about.
Ok finally lets mesure the voltage of the cell
Hmmm they are suppose to have a nominal voltage of 3.3v. The Sub C cells are 1.2v so you can see why we need less A123 cells to make up the equivalent sized pack. However these have a lower nominal capacity of 2.3Ah. I am going to build two 6s so nominal voltage of 19.8V * 2 packs is 39.6V. Some people just use the power drill packs as they are but these only have 10 cells in them so nominal voltage of 33V. The cells should not exceed 3.6V when fully charged. So we have Nominal: 3.3V, Max.: 3.6V, Min.: 2.0V.
I am pretty sure 12 cells are going to be needed what are other peoples thoughts ?
Regards
Jerry
Working on post........
Throttle Controls
Connectors
Regards
Jerry
