Bike recomendations
danielrlee
1,394
723
Westbury, Wiltshire
torquetech.co.uk
No, that's what happens when you notice that it's all worn down, and then do nothing about it.
Fearing that my previous smart-arse comment could come back to haunt me later, I just checked my rims. How does one tell how much wear is too much?
EDIT: Scrap that question. I've done a quick bit of research and apparently I may already have cause for concern. I feel a new thread coming on...
Alan Quay
2,351
1,076
Devon
Some rims have a wear groove on them.
If you can't see a groove then you either don't have a wear groove, or your rim is worn out!
Nerrad
10
Thanks guys for your help, so ive decided to buy this bike I got it for £159 and for the price im sure its a good enough spec to convert, however the weight is around 18kg, how heavy is the 500w conversion kit including bottle type battery?
http://direct.asda.com/Boss-Reactor-Mens-Mountain-Bike---26-inch-Wheels/000975454,default,pd.html&cmpid=ppc-_-ad-pla-_-ggle-pla-_-Cycling-and-Bike-Gear-_-000975454&cm_mmc=ad-ppc-_-ggle-pla-_-Cycling-and-Bike-Gear-_-000975454&istCompanyId=71f4ae42-94c5-4821-aa58-05eff6da2486&istItemId=xqqqxlarw&istBid=tztx
trex
7,703
2,671
the hub kit + battery weighs about 7.5kgs to 8kgs.
You need to order brake sensors for hydraulic brakes if you buy a hub kit or go for an 18A BBS01 kit that does not need them.
That looks like a very good bike for conversion. The only non-straightforward thing will be fitting a brake switch, but there's loads of solutions if you search.
Nerrad
10
Thanks guys for all your help, does anyone have a link to brake switches in the UK? I suppose now my dilemma is front or rear motor, any recommendations, for and against?
Nerrad
10
ok here goes! have I got this parts order correct for my conversion or am I missing something, I will deal with brake sensors later as ive opted for the kill switch on twist grip.
has anyone ordered from this company and had delivery to the UK avoiding customs? also do they ship batteries ok as I know some companies are funny about shipping batteries.
this bike I got for £159
http://www.halfords.com/webapp/wcs/stores/servlet//cycling/bikes/mountain-bikes/boss-reactor-mens-mountain-bike-18?storeId=10001&tduid=2806f9c4429e875ab0de48ea373d3a26&_$ja=kw:2307884|tsid:35533&msg=&cm_mmc=Affiliates-_-TradeDoubler-_-2307884-_-banner&catalogId=10151&storeId=10001&catalogId=10151&langId=-1&seo=true#tab2
total cost £418 not bad for an electric bike, if ive got the parts correct
Alan Quay
2,351
1,076
Devon
If that's BMSbattery then you will have to allow a lot for postage (£100 or so), and you will almost certainly have to pay import duties (£60 ish).
While you are about it, I would order a spoke key, and a freewheel. If you can, order a few spokes as spares.
I have never had a problem with them delivering batteries.
Edit: And you also want a speed sensor, and the switch on the throttle won't work as a kill switch without a relay/softswitch of some kind.
Nerrad
10
Thanks for the advise Mike, I am also in Devon.
Do you know of any suppliers in the UK that can supply these parts, I didn't realize the postage was £100 plus import duties on top?
You have a master switch on the LCD, so you don't need the throttle switch. Use that for lights with one of those Banggood lights.
The bottle battery in your list is not really strong enough for the BPM. You'd be much better off with this kit that has an included 20A sine-wave controller:
http://www.bmsbattery.com/36v/678-bottle-ebike-battery.html
You'll need to order a torque arm and their spoke key, plus you'll need to order a 11T free-wheel gearset from Cyclezee (£25).
C
Cyclezee
DNP 7 speed 11to 32t freewheel £26 + £4 for delivery, Cyclezee torque plates /arms £12 per set including delivery if bought direct.
Alan Quay
2,351
1,076
Devon
No one in the UK can compete on price as far as I'm aware.
I always reckon about £500-650 for parts (inc delivery/duty) on top of the bike.
I built a BPM 500 rear kit for a friend the other day. I used a 10ah battery, and s06 controller. Works fine, although not as much grunt as could be achieved with more current.
If you are not heavy, that'll be fine.
Where in Devon? Happy to let you have a go on my various bikes if you want get a feel for it....
trex
7,703
2,671
Woosh have rear 26" 350W BPM motor with 20A Lishui controller, LCD, thumb throttle, torque arm and 15AH bottle battery for £500. That's about as near to direct import as you're going to get. It's not CST though, you still need a DNP freewheel if you have more than 7-speed.
The front BPM kit of course does not interfere with the gears.
Nerrad
10
Yes im starting to realize that now, Im probably going to go for this battery and get the rest of the kit from this country or are they going to charge the same postage just for the battery? [url]http://www.bmsbattery.com/36v/678-bottle-ebike-battery.html[/URL]
Im in Plymouth
Nerrad
10
I will take a look at their site, I may go for the front wheel hub as its less hassle
Nerrad
10
Thanks for the info, much appreciated!
8,536
Woosh have more bpm kits now on there web site inc a rear 350w 700c (£500) kit which I may consider over the bbs01 18a. How ever they are not due until 10 Sept.
